Originally Posted by Beemie
I can't imagine that double nutting will get the tight enough to seal on the reinstall.
Beemie,
Well actually that is the way. However, I do use thread locker
and a stack of washer to keep the stud from bottoming out in
the threaded hole by just a little bit. Basically you double nut
place the washer on, then the thread locker, finally tightening
the whole works. Let it set up for 24 hours. Break the nuts
loose, and remove the washer and you are good to go.
Pookybear
