Technical skill test for today - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-29-2009, 05:26 AM   #1 (permalink)
Favourite Bike: '72 Bonneville
RetroRod's Avatar
Other Motorcycle: Suzuki GSX1400
Hi all,
Never was any good at IQ tests that included engineering type tests so I really need to pick someone's brain on this.
Rebuilt my '72 650 engine with .020, 9:1 pistons. The head was shaved .004". I do not know the previous history on the head, viz, whether a previous owner had the head shaved also.
Achieved .060" sqeeze on the PRTs using the the smallest thickness neoprene seal, and a standard .040" copper gasket.
I am really wondering whether any of these changes from standard are likely to alter the piston:valve clearance. I am guessing it would not make any appreciable difference, but like I said, I'm a dunce when trying to work these things out. RR
RetroRod is offline   Reply With Quote
Old 06-29-2009, 06:42 AM   #2 (permalink)
Favourite Bike: T120V
Caulky's Avatar
The standard copper head gaskets are .048".
It is very unlikely that your pistons and valves will touch.
See:
http://www.triumphrat.net/classic-vi...-kickover.html
(page 10)
The plasticine in the piston recess confirmed I had 1/8" or so clearance, but I had fitted a .070" `extra thick` gasket. (There`s reasons for using this gasket, 9.5:1 pistons, etc).
This was a rather extreme situation, I think.
Refurbished head with new valves and seats, new barrels and pistons and no idea how much had been skimmed off.
Caulky is online now   Reply With Quote
Old 06-29-2009, 08:08 AM   #3 (permalink)
Favourite Bike: T120R Bonneville (mine)
Other Motorcycle: I wish
Hi RetroRod I run 11.1's on my Bonnie and have had the head skimmed, and had no contact problems If you are worried and want to check use Caulky's idea and stick some plasticine on the pistons.
Plewsy is offline   Reply With Quote
Old 06-29-2009, 07:11 PM   #4 (permalink)
RetroRod's Avatar
Hi guys,
It occurred to my non-mechanical brain last night, that this is most probably more of an issue where vavle timing and lift are changed.
I am a worry wart for sure, but we all know these Triumphs have a capacity to let us have it in the neck if we drop our guard. Thanks again. RR
Took a test ride today.... devilock76 The Rocket Science Forum 27 06-14-2009 06:27 AM
1st test ride today multimoto Twins Technical Talk 3 02-07-2008 06:14 PM
First Test Ride on a New '06 ST with ABS Today mlavin00 Sprint Forum 14 05-17-2007 05:47 PM
failed bl**dy test today Alpha RAT - United Kingdom 4 10-16-2006 04:40 PM
Just got my 99 Tiger today...have technical questions 99TIGER Tiger Chat 4 05-31-2005 09:49 PM
