About time! My Bonnie OIF gets an oil change (VIDEO) - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-28-2009, 07:42 PM   #1 (permalink)
Favourite Bike: T120R Bonneville (mine)
Other Motorcycle: I wish
The past few days I have been up to my eyes in carburetors the ones I use have been very rich for a long time I have tried all sorts to get them leaner to no avail. My mate gave me a set of carbs which are a few years older than my own so I did a strip down on them and flatted all the surfaces poked all the jets fitted them and............they where rubbish.
So I fitted the originals back on, as they have been so rich I have done an oil change because of the petrol flush I expect has happened. Removing the top hat filter I found a crack had opened up at the top of it, so out came the solder and a repair was done to it, I will replace it as soon as I get one. Any way heres the Oil change (it only took me two days ).
http://www.youtube.com/watch?v=W5C8nIg67jk
Plewsy is online now   Reply With Quote
Old 06-28-2009, 09:34 PM   #2 (permalink)
Favourite Bike: Triumph Bonneville
Other Motorcycle: Triumph Speedtriple
Another great vid Plewsy!
I've got a spare top hat gauze filter if you want one (changed mine to a T140 paper job) PM me your address and I'll throw it in the post.
Webby
Webby is offline   Reply With Quote
Old 06-28-2009, 09:42 PM   #3 (permalink)
Favourite Bike: 1979 Bonneville
Plewsy,
Ah, yes now that is what we are talking about. Good job on
the video. But what about the Primary? Or is your's seperate
from the engine oil?
I always change that at the same time.
Pookybear
pookybear is offline   Reply With Quote
Old 06-28-2009, 10:01 PM   #4 (permalink)
Originally Posted by pookybear View Post
Plewsy,
the video. But what about the Primary? Or is your's separate
Pookybear
Hi pookybear, my ten minutes was up so I did not have time to put it in, I did do it though (honest) I am intending to do a clutch strip down over the next few weeks so I will do a primary side vid and include it then.
As my primary chain case drain plug is cracked , I usually remove the casing altogether to drain and do adjustments.
Old 06-28-2009, 10:09 PM   #5 (permalink)
Webby
Cheers Webby, Thanks for the offer of top hat, I got one on order, and will put it in next time I do the oil ,
I will order a T140 paper filter and we'll do a swap
Old 06-28-2009, 10:48 PM   #6 (permalink)
Hi Plewsy,
No worries mate, it's lying in my box of spares never to be used again.
If you want to convert to the t140 paper filter there's no going back. You will need to cut off the oil scavenge (I think) pipe on the R/H lower side of the main frame tube and blank off the hole. The pipe is replaced by a union on the new sump plate.
Webby
Old 06-28-2009, 11:08 PM   #7 (permalink)
Favourite Bike: 1959 Triumph TR6
Other Motorcycle: 2003 HD Road King Police
Jolly good show!
Red1959 is offline   Reply With Quote
Old 06-29-2009, 08:56 AM   #8 (permalink)
Favourite Bike: T140 E
Hi Plewsy,
Webby
Do You? I didn't. Or am I talking about a different kit?
Mine was a "Charlie's" that uses a B25 (I think ) filter up in the sump.
Like this one.
http://triumphbonneville.com/shopsit...ter%20kit.html
DAVE M is online now   Reply With Quote
Old 06-29-2009, 09:26 AM   #9 (permalink)
Originally Posted by Red1959 View Post
Jolly good show!
Hi Red1959 and thank you
Like this one.
Hi DAVE M
If you have used that filter The standard pick up pipe in the tank could not be used, so would have to be capped off, as Webby says the new pickup is on the new base plate.
Old 06-29-2009, 09:50 AM   #10 (permalink)
Interesting.
Mine's a 79 and the original sump is identical so they must have changed it at some point. Mine was a straight swap.
Time to Change greenman Tiger Chat 9 06-28-2008 03:46 PM
Time for a Change... Ringadingdoo Twins Talk 20 05-25-2008 03:40 AM
Time for a change Kitson Twins Technical Talk 12 08-15-2007 02:41 PM
Time to go for a long ride.....(video) Calitriple Speed Triple Forum 3 09-20-2006 03:53 PM
oil change time. Trident85596 Twins Talk 30 03-22-2006 10:36 PM
