Fuel (Gas) Tank Trim - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-28-2009, 11:02 AM   #1 (permalink)
Favourite Bike: Triumph Bonneville
Other Motorcycle: Triumph Speedtriple
Hi All,
Any tips for securing the chrome centre strip on a 72 OIF fuel tank? I was thinking of a smear of clear RTV. Any suggestions?
Thanks
Webby
Webby is offline   Reply With Quote
Old 06-28-2009, 11:06 AM   #2 (permalink)
Favourite Bike: T120RT
Other Motorcycle: T140V,T140D,T140E,T140J
the center of the 2 strips is held down by the center piece why do you need the rtv?
KADUTZ is offline   Reply With Quote
Old 06-28-2009, 11:09 AM   #3 (permalink)
Because there is still a little bit of movement when the centre piece is tightened and no amount of bending and pulling seems to make any difference. Also it's a pain in the a** to line everything up when refitting the tank.
Webby
Old 06-28-2009, 12:13 PM   #4 (permalink)
you can use clear rtv as a 'gap filler'. I did the same thing to the trim strip on my '70 no rattles and a snug fit.
K
Old 06-28-2009, 12:44 PM   #5 (permalink)
Thanks K,
I'll go ahead and give it a go!
Webby
Old 10-13-2011, 10:34 AM   #6 (permalink)
Favourite Bike: 1972 TR6RV Tiger 650
75jazz's Avatar
Hey Webby! How did this turn out? My painted tank is ready for the chrome strip, but I have know idea how to bend and fit it all into place. Do the tabs in the middle go into the center piece? I can see slots that would allow for this, and they would then be holding down the center piece once bent into place.
Inquiring minds want to know! Any advice would be greatly appreciated.
Thanks,
Ash
75jazz is offline   Reply With Quote
Old 10-13-2011, 12:15 PM   #7 (permalink)
Favourite Bike: 1971 Triumph Bonneville
I used a clear silicone under the chrome gas tank strip to prevent damaging the paint.
And I put the tabs through the holes in the center piece. Never had a problem doing it that way.
danpos is offline   Reply With Quote
Old 10-14-2011, 05:53 AM   #8 (permalink)
Hi 75Jazz,
I did the same as Danpos, I found that the trim still moved a little if you just bent the taps in place under the tank.
The RTV silicon worked a treat and has continued to work for the last two years. Also having the trim stuck in place makes removing and replacing the tank a lot easier.
Webby
Old 10-14-2011, 10:04 AM   #9 (permalink)
75jazz's Avatar
I kind of had that idea, but my painter was worried that the rtv/ silicone would chemically affect the paint underneath, leading to problems with the paint job down the road.
Trim Work: Decals, Badges, Tank Protectors, Other Graphics Diego Street Triple Forum 7 11-26-2008 04:23 PM
tank trim upgrades- rack, chrome spine, etc bentonbilbreyiii Twins Technical Talk 7 06-16-2008 12:35 PM
TT600 Fuel Trim out of whack!! spin Triumph SuperSports 3 03-28-2007 12:08 PM
Gas Tank Trim for Classic (Harmonica) Badge? Neducati Classic, Vintage & Veteran 8 10-13-2005 12:14 PM
Trim for gas tank Tbird02 Hinckley Classic Triples 2 08-22-2004 03:27 AM
