Could be the re-assembly of the master cylinder wasn't done correctly. It is very important to get the piston positioned in the bore so as to allow the correct stroke fully across the fluid supply passage. It must open the supply port when retracted to allow fluid to move in and out of the cylinder, but must also close it off completely when applying the brake. (The Triumph manual will tell you the the rear cylinder can't be rebuilt, and to replace it - this is not true, but this issue is why they don't want the owner rebuilding the rear cylinder). The Lockheed manual gives the following procedure for the rebuild and reassembly of the rear cylinder. Assuming the cups are correctly installed on the piston and the spring and piston assy are installed in the bore, reassemble the cap by screwing it on until first contact just occurs with the plunger flange. Make a reference line on the barrel and the cap at this point with a marker. Next screw the cap onto the barrel (1) full turn until the mark lines back up. Now continue to turn the cap onto the barrel until the locking set screw lines up on the key / groove. This will be less than a full turn (in no case go more than 1+ a partial turn total). Lock the cap set screw in this position. Now set the stop screw clearance for the plunger travel to the spec. in the service manual (I think it's .374" / .376", but check this - if you need the exact number, I'll look it up for you). This procedure positions the piston correctly in the bore relative to the fluid supply passage. The piston must completely pass the supply passage to prevent hydraulic leak-back to the reservoir when applying the brake.
Try this out and see if your problem goes away. Good Luck.
[ This message was edited by: papereng on 2005-06-08 10:28 ]
