Conical brake plate finish? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-28-2009, 07:34 PM   #1 (permalink)
Tiger Dale's Avatar
My '72 TR-6 appears to have some kind of painted finish on it that looks pretty crappy after 37 years. What do I use to either, a) remove the finish or b) repaint/finish it ?
TIA
TD
Tiger Dale is offline   Reply With Quote
Old 05-28-2009, 07:57 PM   #2 (permalink)
a wire wheel on a die grinder(if you have) or wire brush. sand paper smooth if needed
spray paint never hurt anyone and if done right, and on littles parts it's hard to tell the difference.
stewdog68 is offline   Reply With Quote
Old 05-28-2009, 08:01 PM   #3 (permalink)
Favourite Bike: Triumph Bonneville
Other Motorcycle: Triumph Speedtriple
Hi there,
I believe that the conical brakes should be bare alloy (unpolished), although I know that some rear brake plates where painted black. Personally I would strip them back and give them a good polish. It takes a bit of work but the final result looks fantastic. There's a guy on this forum from Brisbane (Aus) who has posted a few photos of his hubs and they look bloody good.
Webby
Webby is online now   Reply With Quote
Old 05-29-2009, 05:47 AM   #4 (permalink)
Favourite Bike: '72 Bonneville
RetroRod's Avatar
Other Motorcycle: Suzuki GSX1400
Hi Tiger,
I've had the front and rear plates polished . I also had the front and rear brake arms, springs, etc chromed. Looks great!!
Aviod painting them as they eventually get chipped and fade, then look terrible. RR
RetroRod is offline   Reply With Quote
Old 05-29-2009, 08:46 AM   #5 (permalink)
Hi Retro,
Your hubs look fantasic, nice work...I'm very impressed.
Webby
TLS brake plate on SLS wheel & forks? Jonny955 Classic, Vintage & Veteran 11 07-05-2010 07:44 AM
Rizoma Conical Signals and Suggestions for a Brake Light idaho_thrux Twins Technical Talk 11 11-22-2007 12:36 AM
Correct position for brake lever on rear conical brake johnquinnell Classic, Vintage & Veteran 11 03-09-2007 04:42 PM
Conical frontbrake vs disc brake happyray Classic, Vintage & Veteran 36 02-21-2007 07:00 PM
Bonneville brake pedal mounting plate Digby Twins Talk 1 06-21-2006 11:51 AM
