Clutch Key Way - Triumph Forum: Triumph Rat Motorcycle Forums
Honda Powersports SportbikeTrackGear
Old 05-28-2009, 03:56 PM   #1 (permalink)
Favourite Bike: '78 T140E
Other Motorcycle: 1972 Cb 750
Clutch Key Way
I am having problems removing the Clutch Hub Key way on my bike. I've tried using a penetrating catalyst, heat, and lots of prying (with various tools. I am on the verge of attempting to take it out with a dremel. Does anyone have any tips for removing keyways? Secondly, if I do go about removing my keyway with a dremel it will have to be replaced. I found a, "Clutch hub key" on raskcycles.com, items 37 - 42 under clutch parts. (sorry I could not get a direct link to this). It says the part number is 60-4253. Can anyone verify for me that this is the part i need to go about ordering, as I do not own a parts book.
Thank you,
Chad Miller
cbm206 is offline   Reply With Quote
Old 05-28-2009, 04:26 PM   #2 (permalink)
Favourite Bike: 1974 T120V
Other Motorcycle: 1972 T120R
Key
Hi,
Presumably you mean removal of the key itself (not the keyway, which is a hole!)?
Have you tried just butting a screwdriver up to it and tapping it out?
Mark
mark61120 is offline   Reply With Quote
Old 05-28-2009, 06:04 PM   #3 (permalink)
Favourite Bike: 1979 Bonneville
Thank you,
Chad Miller
Chad,
Boy there is always more to these things than you think.
Is it a half moon key? Just use a small punch on one end
and it will curl out.
Or a square cut key? Usually one can tap the end of the
key with a small punch and it will pop out as it reaches the
relief cut at the end of the key way.
Or finally the hardest of them all a half moon with two shoulders?
Use a skinny flat tip screwdriver to get under one of the
shoulders, tap and then you can get sometime under it to
pop it out.
As for the part, you can call Mitch Klemphf he is pretty good
about someone not having a part number, and order a parts
book while you have him on the phone.
507-374-2222
Pookybear
pookybear is offline   Reply With Quote
Old 05-28-2009, 08:11 PM   #4 (permalink)
flat head and hammer always work for me.
FYI watch where you swing the hammer
stewdog68 is offline   Reply With Quote
Old 05-29-2009, 02:14 AM   #5 (permalink)
It appears to be a half moon with at least one shoulder. I haven't worked at it much with a hammer and screw driver. I was worried that the play in the shaft could damage something. Thanks for the advice. I certainly prefer this method to ordering a new key. Yes, I ment key, not keyway. Thanks for the tips.
Clutch Rookie Classic, Vintage & Veteran 6 06-05-2008 03:54 AM
Bad clutch??? rigby Hinckley Classic Triples 7 11-06-2007 04:56 PM
*** clutch Ski_rat Club Cafe' 34 07-29-2007 12:37 AM
Clutch Hub Nut Trimac Twins Technical Talk 1 05-15-2007 07:23 PM
Clutch Help Triumph SuperSports 2 10-08-2005 06:31 PM
