Originally Posted by pookybear
Looseparts,
Anyone of the parts jobber listed on the web can supply the
tools needed. Just do a quick search on google for Triumph
parts suppliers.
Which oil are you talking about? The clutch operating mechanism
that is trashed in your photo would have only put metal shaving
into the transmission gear lube.
Pookybear
PS easy tip for the clutch springs next time, those slotted nuts
have a stop on the back side that engauges the top of the spring.
You can take a pocket screwdriver to push the spring down a
little to get the top of the spring off of the stop.
Thank you Pookybear.
Thinking the shavings from the clutch operating mechanism had somehow made their way to the crankcase shows how little thinking I do sometimes. Thank you for your patience!
I tried the knife-under-the-slotted-nut trick (it's in the shop manual). Actually I tried several knives and other thin, stiff things, and what finally did it, was brute force. One knife was of the folding variety and at one point it folded - didn't get cut, just a scare. I could not for the life of me push the spring away from the slotted nut! With enough push and twist, a person can overcome the little stop on the back of the the nut. At times I evoked the name of my favorite nun in Catholic school... "MOTHER FLETCHER!"
The other two did not need the knife - they too came off, but for them, it was just a modest amount of force needed.
I came back from Napa with a couple of pullers that ain't going to work. I will do some on-line shopping for the correct items, but... Shouldn't we form a collective where we can pass a few of these special tools to one another as the need arises? How many of us need to buy and own a 'D2213 Camshaft extractor' to use it once?
If you need any special tools, check back with me in a couple of months - I'll loan you mine : -)
