Originally Posted by Caulky
OIF = oil in frame.
To find out if its wet sumping, leave it for a day and undo the angled drain plug/filter under the engine. If more than 200cc comes out, it is.
So the drop in oil level is due to the sump filling.
Careful Caulky,
Most of these bike love to wet sump. Most of these bike will
also wet sump if you just run it for a minute or so and then
shut it off.
Then you check the oil and the level is low so you add abit
more oil. Next thing you know it is overfull. So always, run
the bike for a few miles to get the sump pumped out. Then
check the oil.
Of course your answer was also right, but not the only answer.
Pookybear
