kickstart loose - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
SportbikeTrackGearMotorcycle.com Classifieds!Honda PowersportsOntario Tourism
Old 05-24-2009, 08:40 PM   #1 (permalink)
kickstart loose
Hi all,
My kickstart 'shaft' (the bit the lever clamps to) is rounded a bit and is chewing through the cotter pins. It still works ok but has a bit of play.
Is there a common quick fix for this? can I put soem weld on it and re-dress the face? Is it easy to replace?
or.... could i fabricate a cotter pin to fit the rounded-ness
cheers
derek
derek
Melbourne, Australia
71 T120RV
Progress blog - http://dirtystriumph.blogspot.com/
delrazor is offline   Reply With Quote
Old 05-25-2009, 12:58 AM   #2 (permalink)
Favourite Bike: '68' T120 Bonneville
Other Motorcycle: 2006 T100 Bonneville
Extra Motorcycle: '79' T140 street tracker
I would imagine you could get away with a little dressing down of the notch but I wouldn't go very far or the cotter won't lock in anymore. It will be cheaper than a new shaft if it works. If it doesn't work, you were going to need a shaft anyway. Make sure the nut is properly touqued on reassembly.
jimmy bush is offline   Reply With Quote
Old 05-25-2009, 01:14 AM   #3 (permalink)
Favourite Bike: 77 Bonneville
OzBloke's Avatar
Take the shaft out of the outer gearbox case, build it up with weld, re-dress carefully, and put it all back together. Worked for me.
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Kickstart for Thruxton IrishJohnny Club Cafe' 26 06-24-2011 05:47 AM
66 Triumph TT kickstart dcportland Classic, Vintage & Veteran 2 11-30-2008 02:35 AM
Kickstart gjohnsonvp Twins Talk 19 09-26-2007 08:40 PM
Kickstart Hinckleys?? jimmydean Club Cafe' 28 03-10-2007 11:48 AM
Kickstart woes nootheridleft Classic, Vintage & Veteran 3 03-02-2005 04:28 PM
