T140 Alternator question... - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-19-2009, 11:01 AM   #1 (permalink)
Favourite Bike: 1973 T140
My original Lucas Rotor is in good condition, but my stator is pretty beat up. Will it be alright to put a sparx stator over my Lucas rotor? Or should I try and find an original? Thanks for any guidance
LukeSmith1985 is offline   Reply With Quote
Old 05-19-2009, 02:07 PM   #2 (permalink)
Completely off track... But can I use a hardening liquid gasket compound I bought at an automotive shop for putting the cases back together?
Old 05-19-2009, 05:09 PM   #3 (permalink)
Favourite Bike: 1976 Triumph T-140V
thirdbike's Avatar
Other Motorcycle: 1950 Matchless G80
Extra Motorcycle: Yamaha 1200
For your cases try something like Loctite 515 which is an anaerobic gasket maker. Use only a little bit - a thin film. I cleans up real easy, doesn't stain anything easy, not messy to work with, removes real easy if you need to go back inside and, best of all, it works like a charm.
Can't help you with the Sparx sizing issue - never seen one. Your stator is repairable though. There's very little to go wrong unless you fried it. I'm betting the feed wires is what has you all concerned - the insulation has stiffened and the connection to the stator itself is so so. Replace the wires and don't forget to put a piece of loom over the outside.
thirdbike is offline   Reply With Quote
Old 05-20-2009, 09:17 AM   #4 (permalink)
Thanks for the tip Thirdbike,
There is another problem with my alternator... When the engine was dismantled before I purchased, the wire was cut right where it come out of the case. Would it be alright to splice that wire?
Old 05-20-2009, 11:42 AM   #5 (permalink)
thirdbike's Avatar
To splice, ensure you have a very secure connection using a good quality crimp fitting and then shrink tube it to seal the joint andensure problem free service.
78 t140 ignition question cbm206 Classic, Vintage & Veteran 2 09-27-2008 12:49 AM
Newbie with T140 Clutch Question sdirwin Classic, Vintage & Veteran 9 08-11-2008 06:06 PM
Basic Oil Question - '78 T140 Cguzman Classic, Vintage & Veteran 8 02-01-2008 10:59 AM
76 T140- Amal Carb jetting question glw Classic, Vintage & Veteran 6 01-01-2008 07:19 PM
Just got a new(for me) 76 Bonnie T140, question on the bars.. glw Classic, Vintage & Veteran 10 03-29-2007 06:34 PM
