Hi BonnevilleJoe;
4 what it's worth...
My bike is a '78 Bonnie, and I needed to remove everything from the frame to get it welded (along swingarm as oil was leaking outa OIF)... so I had to remove the rear master cylinder also.
I didn't have any trouble getting onto the nuts, on the inside, it was holding the bolt head for that one bolt that has almost zero clearence. I found that I had a tool-kit wrench from my Volkswagen days, made out of stamped metal, thin, 13mm, and it fit just fine.
Now I've since learned that the master mounts to a plate that also comes off, if you have the motormounts off.
suspect this is all water under the bridge, as you have solved the mystery by this time.
gotta enjoy turning a wrench with these old Bonnies, roight? :hammer:
DUM VIVIMUS VIVAMUS
Let Us Live While We Live
