Originally Posted by jfritts
Hi. I've come to a dead end. Can't quite figure out why my front blinkers both dimly light at the same time regardless of what direction the switch is.
Thanks!
Jfritts,
If the rear turn markers are bright, it will have to be either a
gound problem on the fronts or the lucar connectors in the
headlight shell. Just trace the wires from the markers into
the shell and you will find the connector.
As for the rear brake, does it not work with either the petal or
the hand brake?
Pookybear
