+ is Positive, - is Negative
What tnsen said...
But I would not wire in the plug-n-play "adapter." As it is a "reverse" grounding system oth the old Triumphs, if you leave the USA adapter cap off you may melt down your wiring harness if the exposed - lead hits the chassy +, since the USA is reverse of old Brit (Positive) ground side.
+ is +, and - is -, where ever it comes from and how.
Use the Battery Jumper Clip Ons, if it is you got a Battery Tender Junior or the like. Or you may want to cut and rewire your Tender for a safer long term isolated solition if you desire to wire in the adapter perm. But judging from your original question, you probably shoudn't do that...
- Packy, the
'04 B&W T100
The Bike I Ride
