Rebuilt engine new amal carb hard to start when cold? - Triumph Forum: Triumph Rat Motorcycle Forums
Honda Powersports Motorcycle.comNew Bonneville
Old 04-21-2009, 09:50 PM   #1 (permalink)
Hi,
I just rebuilt the engine on a t100r; rings, pistons, bearings, new valves, and installed 1 new amal 626.
It was starting good but I could not get it to idle and run right so I changed the needle valve to the lean position and it runs & idles better but when it is cold, it's real problem to start, sputters, backfires, choke or no choke doesn't matter. After I finally get it to run and warms up it does fine. It has a new boyer and the battery is 12volts cold. 125 lbs compression on both sides. I'm gonna switch the needle back tomorrow and see if that is it, but I'm still baffled.
Thanks for all replies.
10drum is offline   Reply With Quote
Old 04-22-2009, 12:20 AM   #2 (permalink)
Favourite Bike: '68' T120 Bonneville
Other Motorcycle: 2006 T100 Bonneville
Extra Motorcycle: '79' T140 street tracker
I put two new Amals on my T120R while doing an overhaul. Same results. Coldest natured bike I've ever owned. Haven't got it figured out yet. Runs like crud when cold, fine when hot. I haven't got the air valves in mine and was hoping that installing and using them would be the cure. Maybe not. I know the jetting (main and needles) is a lot leaner on the new carbs than what I had in the old ones to get a good plug color. Old carbs had 220 mains, 107 needle jets, needles in the middle groove. New carbs have 200 mains 106 needle jets and needles in top grove.
jimmy bush is offline   Reply With Quote
Old 04-22-2009, 01:40 PM   #3 (permalink)
Favourite Bike: '67 Triumph Bonneville
That's why I like to have the enrigher (choke) slides.
Loosen the choke cable slack to lower the slides down, tickle the buttons till you get a good healthy dribble for a second (they really like to have flooded cylinders when cold), then a mighty kick like you mean business. Should start right up and idle with a blip or two.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 04-22-2009, 02:48 PM   #4 (permalink)
10drum is having the problem choked or not. Wonder if he might have an air leak that is closing up when the manifolds heat up and expand? (hey I wonder if I'm having the same issue?) Or maybe the re-designed Amals are just very cold natured. If I can't sort mine out I might put my old ones back on with some new chrome slides.
TT600 hard to start cold, then there's the stator... samurye Triumph SuperSports 11 04-15-2009 07:52 AM
1966 T120C - Starts when cold, Hard to start after warm up surfdogx Classic, Vintage & Veteran 1 10-10-2008 04:55 AM
Engine stalls seconds after cold start Dylan Sprint Forum 24 08-15-2007 09:31 PM
Cold start up engine miss????? jerseyjeff Twins Technical Talk 2 07-14-2007 10:09 AM
Tiger 05 Engine hard to start any suggestions Mutley Tiger Workshop (archive) 5 08-19-2005 04:35 PM
