Site Supporter SOTP Vintage Series Favourite Bike: '67 Triumph Bonneville
Posts: 7,674 Other Motorcycle: British Iron Extra Motorcycle: Dreer Norton Prototype
With the shared primary oil, you need to keep it really clean.
make sure your clutch pressure plate spring adjusters are turned in as mentioned, but I believe the bolt ends should just be visible one full thread in the slot on the head.
You need to slacken the cable off to 1/8" free play at the lever, then unlock the pushrod adjuster nut; loosen the center grub screw, then turn it in till it just makes contace, and back out 1/4 turn. Snug the nut back down with a socket with your fingers, while holding the grub srew in position with a screwdriver through the socket; once it snugs up, lock it down.
Should be good to go.
When you serviced the oil level in the primary after installing the clutch, you shouldn't have poured in more than 1/4 cup. If you did, you might need to pull the plates back out and wash them thoroughly, let them dry in the sun, and start over.
