Crank case ventilation question on a 69 T100R - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!SportbikeTrackGearHonda PowersportsNew Bonneville
Old 04-18-2009, 09:50 AM   #1 (permalink)
Greetings,
What does everythink is the best/cleanest way to ventelate the crankcase on engines with the vent tube under the engine by the main sprocket?
I've heard run a tube up under the rear fender, don't vent the oil tank, and I've also heard to install a vent on a rocker box cover and "T" it into the crank case vent.
Just curiuos. Thanks for all replies.
10drum is offline   Reply With Quote
What does a Crank Case Breather do TowerGuy Twins Technical Talk 4 02-13-2009 02:58 AM
Crank case breather connection sagaris Daytona Deliberations 12 01-13-2009 04:48 AM
getting the crank out of the case? wingnut Classic, Vintage & Veteran 5 09-05-2008 09:31 AM
Crank case breather bhought Classic, Vintage & Veteran 10 06-13-2007 10:28 PM
Crank case full of gas Lurch Maintenance & Workshop Talk 5 03-22-2005 11:12 AM
