all of the sudden no compression in one of my cylinders?, help!
all winter long i have been working on my bike i never touched the motor though. i was just making it into a chopper of my taste rather than the previous owners taste. i have 1966 tr6 and it would start right up everytime on the third kick at most. ive ridden it last fall a couple of times and then i would start it up every once and a while during the winter while it was up on the work bench. so last weekend i took it off the bench since i had it all mocked up and decided to take it for a ride up the street a couple of times. it started on kick #3 and would rev but in gear at low rpm it would wanna die so i revved it higher then let the clutch out and off i went but it was running really bad lots of flames and back firing from the exhaust so i adjusted the carb back to what my haynes manual says to go from and then it starts but the idle needed adjusting so it stalled i turned the idle screw and then it would not start. so i'll kick it alot and all it does now is shoot about a 1 foot long flame out of one pipe POP like a gun going off and nothing from the other. so i took my spark plugs out and kick with my thumbs over the holes and blows it off the head on one side and on the other it does not meaning no compression. what could it be. the last it ran was when the idle was not enough and just stalled it does not seem normal that that could happen at low rpms like idleing. so i dont think the rings are done i feel as if an exhaust valve is stuck open or something but then i think the piston would be hitting it, let me know what you think i should check out. thanks every one.
