Old 04-27-2005   #1 (permalink)
Ok, On my 71 Bonni the manual I have shows the rear shoe lever that connects to the rod from the pedal mounted pointing down. I recently visited a shop with plenty of Trumpets and most of my vintage have the shoe lever pointing up, (causing the rear brake rod to angle up towards the rear). Is this for better brake leverage, worn pads or do I have mine on upside-down. If this makes sense any thoughts would be appreciated.
Regards, sprintyelf. :-g
Old 04-28-2005   #2 (permalink)
DAGAD's Avatar
Should be pointing UP. Between 1 and 2 o'clock as you look at it. Roy
Old 04-28-2005   #3 (permalink)
Thanks Dagad, I'm know completely convinced there's nothing about Triumphs you don't know. Thank you for replying to even the smallest questions like this one. Cheers to you.
Regards, sprintyelf :chug:
Old 04-28-2005   #4 (permalink)
DAGAD's Avatar
Thanks Sprinty, I wish! There are far more knowlegable people than me on Triumphs. Keep this a secret between us, I know one or two of them! Roy
Old 04-29-2005   #5 (permalink)
Roy, you are without a doubt the most knowledgeable guy here, and you give great advice. But, (with all due respect) are you certain about that?
On both my '71's the lever on the brake plate points DOWN to the rod at about 6:00. Been like that forever, and I don't really see how they could be assembled any other way.
My '66 had a different style wheel with the lever as you describe.
Triumph made some major, unpopular, and shortlived design changes in '71, including the 'comical' wheels and brakes.
I think sprinty's manual is right (if it's a '71 wheel. maybe it isn't?)
If I'm wrong, I promise to give myself 20 lashes with a tommybar and refrain from all drunken posting for a period of 30 days.
Best regards, and thanks for sharing your knowledge.
steve
oilyboot is offline   Reply With Quote
Old 04-29-2005   #6 (permalink)
steve
Old 04-29-2005   #7 (permalink)
Well with respect to both DAGAD and oilyboot I may just machine a new lever and point it at say....3:30. Just kidding. I did see a 73 Bonnie with the same looking rear brakes as mine pointing up, but thats why i posed the question because 1 it seemed contrary to the manual and 2 look a bit off with the rod rising up to the back. It would seem to me that either way is going to expand the shoes opposite?
Regards and thank you, sprintyelf
:-g
Old 04-29-2005   #8 (permalink)
:-g
Old 05-01-2005   #9 (permalink)
DAGAD's Avatar
UREKA, I've found the answer
From April 1971 on, thicker linings, together with thicker fulcrum pads and the necessary longer rear brake cam lever with newly introduced return spring was fitted.
The new longer lever was installed 'upwards' instead of underslung as previously.
There is no recorded engine number change point for these alterations to restore braking efficiency, I would guess around DE20000 onwards.......but this is only a GUESS. Roy
Old 05-01-2005   #10 (permalink)
Thank you, Roy.
You ARE the man.You've provided yet another bit of valuable information that the guys who wrote my manuals didn't include.
Where did you find that piece of ancient history?
Thanks again.
Steve
ps I actually had to go out to the shop and look at both my back wheels before I posted on this subject. It seemed more likely that I was assembling my brakes wrong than for you to provide any incorrect info...
Brake pad type for rear oldyeller Modifications & Workshop Talk 4 08-20-2007 12:44 PM
Correct position for brake lever on rear conical brake johnquinnell Classic, Vintage & Veteran 11 03-09-2007 03:42 PM
Rear brake pad replacement DragonDan Sprint Forum 3 04-03-2005 05:39 PM
Rear brake pad changes 96 tbird jhusman Hinckley Classic Triples 3 11-03-2004 04:11 PM
Replacing the rear brake pad EricMichael Hinckley Classic Triples 2 08-02-2004 10:41 AM
