There should be a valve that let's air into the tank, but not out. Sometimes this is incorporated into the gas cap. I'm not sure if it's like this on the Tiger. There should be another valve that lets air to the charcoal canister, but not back to the tank. If they're both not pointed in the right direction or get blocked, you'll have expansion/compression problems. Your bike can run rich or lean depending on which condition you end up with.
I believe i read recently there were about 3,000 Sprints (MY2008) that had a similar issue. I'll have to look it up again.
Those who behave like sheep should not be surprised when they get fleeced.
