The sixth gear is amazing - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsMotorcycle.com Classifieds!SportbikeTrackGear
Old 06-29-2007, 06:29 PM   #1 (permalink)
Favourite Bike: 02 Trophy 1200
In an earlier post is mentioned that I have been riding my Speedmaster for a litttle more than 2 years, and other bikes before it. All of them had four or five gears. About 10 days ago, I lucked up on a 02 Trophy wih only 400 miles, bought it and have been riding it as much as possible.
The Trophy has six forward gears, and for highway riding it is a dream. 3,000 rpms equals 62 mph, and it red-lines at 9500 rpms. You really have to watch your speed if you want to avoid a ticket. The sixth gear almost adds a new dimension for touring.
I put a larger front sprocket on my Speedy, and that helped a lot, but a sixth gear would have removed that necessity.
Why hasn't Triumph added that extra gear, or does someone know of some reason the could/should not?
Matter can neither be created or destroyed, but it can be lost.
brolane is offline   Reply With Quote
Old 06-29-2007, 06:48 PM   #2 (permalink)
Administrator
Favourite Bike: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
Interesting question.
As it was once explained to me and as I understand it (I could be wrong in my assumption), increasing the ratios from 4 to 5 gears in a transmission, most of the bits are there to add the extra 6th gear anyway.
So the number of ratios could be economically done in multiples of 2.
Maybe things are different with modern transmissions?
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is offline   Reply With Quote
Old 06-29-2007, 09:37 PM   #3 (permalink)
There may not be room enough for a sixth set of gears, but more importantly to the bean counters, is that every set of gears costs money. My gripe is that on an engine like the Bonny, you could easily have a lower 1st, and a overdrive 5th. I can run at highway speeds in 3,4,and 5. 5 is undrive 1.07, the same 2 gears would also give .94 if reversed. Anyone want to start a searching tooth gear thread?
kdrake is offline   Reply With Quote
Old 06-29-2007, 10:00 PM   #4 (permalink)
Favourite Bike: 2008 1050 ST
rs_tt's Avatar
Other Motorcycle: 02 Sprint RS..sold
+1 to what wombat said ,
tec told me every thing is there for 6th, but not enough space to make it reliable.
rs_tt is offline   Reply With Quote
Old 06-29-2007, 10:47 PM   #5 (permalink)
Administrator
Wombat's Avatar
So with a small redesign of the casings, which god knows was done enough times on the triples, they could probably slip the 6 speed tranny from the triple line into the twins.
Bob
Old 06-30-2007, 10:51 AM   #6 (permalink)
Favourite Bike: Modified 2005 T100
Other Motorcycle: 1994 CB750
Put it this way in top gear (already with a bigger front sprocket) I am at redline at 115 mph without even on full throttle. Just about says it all!
With the modifications done to my engine it is more than capable of doing 125 given the proper ratio's
Every sunday is mad sunday.......
BeastInBlack is offline   Reply With Quote
'02 955i / Wisconsin / Gear, gear, gear. wwpageiv Daytona Deliberations 2 06-07-2007 12:24 AM
Amazing! welshrob Biker Hang-Out 4 01-23-2007 10:14 PM
Searchin' for Sixth zighawk Twins Talk 20 09-28-2005 10:05 PM
955 and sixth gear WildBill Speed Triple Forum 1 08-22-2005 01:21 AM
changing from fifth to sixth gear MrEd Speed Triple Forum 8 07-14-2005 04:02 PM
