I know it's real. I've looked up several related items on the internet. I think you may be right about it being part of the EFI. I know it was a computer adjustment they made to correct the problem.
He may have tried to simplify the terminology so I could understand it. The following is from a write up on the 955 sprint.
With a displacement advantage of 174cc over the VFR, the torquey triple has more low and midrange power. Unfortunately, it give up a full 9.5 hp on top to the Viffer, though acceleration is similar, due to the increased torque. Response from idle is better than ever, too. Triumph attributes this to newly revised throttle bodies, with butterflies at 5° instead of the previous 12°, a new stepper motor-controlled air bypass system for low-speed control and a bigger airbox borrowed from the new Daytona. It also tapped some British airflow experts at Lotus for help with cylinder head porting. All in all, it provides the rider with an exciting blend of low down grunt and midrange muscle.
sounds like it controls the air/fuel flow?
I'm an individual, just like everyone else.
Previously owned 2006 Sprint, 2007 VFR.
