Fuel tank Baffle/Explosion prevention foam! - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 12 (permalink) Old 05-04-2013, 05:18 PM Thread Starter
Main Motorcycle: KTM 1290 Super Adventure
ArferBrick's Avatar
Other Motorcycle: '96 Adventurer
From the website-
Further Information.
Explosion Suppressant Foam is reticulated polyurethane foam and is used in fuel tanks where the possibility of fuel tank explosion exists. Also known as ESF, or Safety Foam, the product was invented in the late 1960s when the United States Air Force began using reticulated polyester polyurethane foam to suppress fires and explosions inside fuel tanks.
Explosion Suppressant Foam has now been used for over 30 years and has found thousands of successful applications in aircraft, boats, military vehicles, competition and emergency vehicles.
Over the years the ESF for suppression of aircraft fuel tank explosion has evolved into seven generations of development often referred to as Type, for example Type 1 being the original polyester foam used by the USAF.
Each foam Type is qualified for all competition uses and approved by the FIM. This listing is for type 2 yellow foam.
Once installed inside the fuel tank the reticulated polyurethane foam essentially functions as a three dimensional fire screen. The foam is 98% void and only reduces fuel volume by 4% and adds only a negligible amount of net weight to the fuel tank.
I guess another benefit is that it could possibly prevent rust forming in tanks because of the eliminated airspace when a tank is empty.
EDIT:
And another idea - it might also act as a fuel filter too, as the fuel goes in the foam would trap any medium to large particles.
ArferBrick is offline
post #12 of 12 (permalink) Old 05-04-2013, 06:40 PM
Main Motorcycle: Speed Four
spank86's Avatar
Other Motorcycle: HMS ThunderAce
I do wonder if it would have any issues with gravity instead of pump fed systems?
Ever thought this forum might be a lot less random if any of us actually read the contents of each others posts?
You don't have to be stupid to be wrong, and you don't have to be wrong to be stupid.
spank86 is offline
Sea Foam in tank, crankcase, and vacuum tubes? jac55 Air Cooled Twins Technical Talk 22 04-07-2012 09:21 AM
Fuel tank Foam blocks chopped knuckles Speed Triple Forum 11 06-08-2011 06:35 PM
Does the EFI gas tank have a baffle? Mingo09 Air Cooled Twins Technical Talk 5 04-10-2010 03:14 AM
Scrambler baffle / air / fuel advice please? BrianM Air Cooled Twins Technical Talk 10 10-22-2007 06:45 AM
