Tire gas alternatives - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Motorcycle.com Classifieds!
Old 12-30-2012, 06:06 AM   #1 (permalink)
Main Motorcycle: 02 SkeleTona 955i CE
Nelsifer's Avatar
Lightbulb Tire gas alternatives
A guy at work was talking about how he just got Nitrogen fill in his pick up. He told me how it was better to have N2 in the winter months because of the constantly changing pressure and temperature. see Charles Law
It got me thinking. Has anybody used anything other than air or N2 in their tires?
As a diver I use Argon, Helium, Nitrogen and Oxygen in different mixtures on a regular basis. Well, I would like to use Argon more as it is winter and friggn cold. Breathing gas used is always determined by depth and duration. 90% of the time it's plain old air.
From what I've read about these N2 fills is that O2, the 21ish% of Air, eventually seeps out. A 100% O2 fill would not likely be a good choice.
Helium is a very light gas and conducts heat very well (about 6x better than air I think). You can see how this would be a problem, especially for you track rats. See Charles Law. Have you ever checked your tire pressure cold and then again after a 20 minute ride? It's usually a few PSI greater when it warms up.
Argon would probably be my best choice. That is, if it were more affordable.
Argon is a denser gas and is not a good thermal conductor. If it were in your tire it give you significantly less expansion. I don't know however if it would have an effect on traction. I guess it depends on your tire quality.
Ride fast, take chances...
-Reupholstered Seats
-Bar Conversion
Nelsifer is online now   Reply With Quote
Old 12-30-2012, 11:24 AM   #2 (permalink)
Main Motorcycle: 98 T595
Ahks's Avatar
The biggest bonus for me in running nitrogen fill is the lack of oxygen... since water is h2o. Using a higher concentration of nitrogen keeps moisture out and helps prevent corrosion. Wheel corrosion can be a big problem depending on environment and has been a significant issue on my cars wheels.
P.S. Thank you DEcosse
http://www.customfighters.com/forums...0&goto=newpost
Ahks is online now   Reply With Quote
Old 12-30-2012, 12:44 PM   #3 (permalink)
Main Motorcycle: 09 Sprint ST ABS
Billbikes's Avatar
Other Motorcycle: Lemond Zurich
I'd fart in the tires, but the nozzle sounds painful....
09 Sprint ST-Trident exhaust,rear fender tidy.
You can take the boy out of Texas, but you can't take Texas out of the boy.
Billbikes is offline   Reply With Quote
Old 12-30-2012, 02:14 PM   #4 (permalink)
Main Motorcycle: 1995 Daytona 1200
SlowPocono's Avatar
Other Motorcycle: 1979 T140E, '06 Scrambler
Extra Motorcycle: 851 Sprbk, YZF R-1, SV650
I use a mixture of nitrogen, oxygen, argon, and carbon dioxide exclusively.
SlowPocono is online now   Reply With Quote
Old 12-30-2012, 06:26 PM   #5 (permalink)
Legend
Main Motorcycle: '07 Bonneville
Haggis's Avatar
Other Motorcycle: Sprint RS
I've been putting nitrogen in my tires for aeons!
Just like SlowPocono
Haggis is offline   Reply With Quote
Old 12-30-2012, 06:26 PM   #6 (permalink)
Main Motorcycle: Speed Four
spank86's Avatar
Other Motorcycle: HMS ThunderAce
The ONLY benefit of nitrogen is the lack of moisture.
If you live in Arizona it's probably not worth it.
If it were true that the oxygen escapes the every time you filled your tyres you'd be increasing the amount of nitrogen in total until it was almost the same as from a bottle.
Ever thought this forum might be a lot less random if any of us actually read the contents of each others posts?
You don't have to be stupid to be wrong, and you don't have to be wrong to be stupid.
spank86 is offline   Reply With Quote
Old 12-30-2012, 06:39 PM   #7 (permalink)
Main Motorcycle: 1996 Thunderbird
Bloody Knuckles's Avatar
Other Motorcycle: Suzuki JR50
This sounds like the same mixture I use. I highly recommend it for filling tires and other general uses. In fact, I have found it so useful that I can't seem to live without it.
1996 Thunderbird -- RaceTech fork springs, Ricor Intiminators, Unrestricted carb rubbers, Corbin seat, Norman Hyde M-bars, StainTune Exhaust.
Bloody Knuckles is offline   Reply With Quote
Old 12-30-2012, 10:49 PM   #8 (permalink)
Main Motorcycle: Triumph Tiger 800XC
NORTY FLATZ's Avatar
Other Motorcycle: Harley FXD
With TPMS devices that have batteries, it's not a bad idea to use an inert gas that doesn't support moisture (humidity).
Costco offers it free to members...
You can't put a price on a good time!
NORTY FLATZ is offline   Reply With Quote
Old 12-30-2012, 11:42 PM   #9 (permalink)
Supernova
Main Motorcycle: 2011 Sprint GT 1050
DaveM's Avatar
Extra Motorcycle: Previously - Many
I've been using Helium for years, keeps the unsprung weight down, stops corrosion and makes my tyres talk in a squeaky voice.
My album click here;
http://www.triumphrat.net/memberalbu...er/2712/sort/3
DaveM is online now   Reply With Quote
Old 12-31-2012, 12:08 AM   #10 (permalink)
Nelsifer's Avatar
LOL... Should have specified. Oh well, I wont get into breathing mixes.
-Bar Conversion
oil filters that fit!! OZ alternatives ???? miley800 Twins Technical Talk 61 12-06-2011 06:57 PM
RHS switchgear alternatives..? eddyfiola Classic, Vintage & Veteran 7 05-18-2011 01:56 PM
Saddlebag Alternatives slowgator Twins Talk 5 04-06-2011 10:54 PM
Gaiter Alternatives faulkner Twins Technical Talk 4 08-23-2009 09:18 PM
Oil Filter Alternatives BrianM Twins Technical Talk 22 11-08-2007 04:02 PM
