So I fell yesterday.... - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-05-2012, 11:36 AM   #21 (permalink)
AMC
Main Motorcycle: 2006 Bonneville T100
Originally Posted by Thruxtonbill View Post
Nothing to ad here other then glad you're ok.
Did you bend the rear brake lever or the front? I have a spare OEM front lever if you need, just PM me where to send it.
Wow! Thanks Thruxtonbill. I sent you a PM with all of my info.
AMC is offline   Reply With Quote
Old 12-06-2012, 11:56 AM   #22 (permalink)
Main Motorcycle: 09 Bonneville Black
LittleJoe's Avatar
Other Motorcycle: 02 Ducati 748S
Extra Motorcycle: Kawi ZX-7R (trackbike)
AMC, glad you're pretty much unhurt. It does happen to everyone, especially at slow speed. The only way to learn to ride though gravel is to do it. Great advice from other posters on not using the front brake when in the stuff but to concentrate on the rear.
You can safely navigate though it, look where you want to go, but also keep the bike as up right as possible. Try to angle yourself to take as straight as a line as possible though the gravel. If that is not possible, keep your movements and bar inputs as smooth and deliberate as possible.
LittleJoe is offline   Reply With Quote
Old 12-06-2012, 12:03 PM   #23 (permalink)
Main Motorcycle: 2011 Tbird
BMK9251's Avatar
Originally Posted by AMC View Post
Now a question for all of you experienced riders out there. What should I have done differently, and what things should I check on my bike after a fall like this? The bike seems relatively unscathed. The only damage was the brake lever and the turn signal. Other than that, I didn’t even see any scratches on it.
Thanks and ride safe!
1. check the whole bike closely. If you are unsure consult your mechanic.
2. invest in an engine guard. (dresser bars)
3. re-evaluate your riding gear.
4. ride on.
BMK9251 is offline   Reply With Quote
07 TBA Fell Over....Looking for TIPS BCTriumph Twins Technical Talk 12 12-07-2012 12:32 AM
What fell off my Scrambler? tvscum Twins Technical Talk 11 12-01-2012 01:01 PM
Fell in love... MGoBike The Welcome Center 3 09-03-2012 11:58 PM
Ouch I fell down... yakoo11 Triumph SuperSports 14 10-27-2009 02:32 AM
1st part fell off. Geoff Twins Technical Talk 12 07-18-2007 09:33 AM
