Too Cold?? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-24-2012, 09:34 AM   #1 (permalink)
Main Motorcycle: 09 Sprint ST ABS
Billbikes's Avatar
Other Motorcycle: Lemond Zurich
Too Cold??
I was wondering when was everyone's limit on cold and riding???
Personally, it's not so much the cold, as it is the crud that makes the roads treacherous. Down to freezing, no problem, but I do Plug in for anything below 50º for extended periods of time....
09 Sprint ST-Trident exhaust,rear fender tidy.
You can take the boy out of Texas, but you can't take Texas out of the boy.
Billbikes is offline   Reply With Quote
Old 11-24-2012, 09:36 AM   #2 (permalink)
Under 40° F is too cold for me.
Old 11-24-2012, 09:38 AM   #3 (permalink)
Main Motorcycle: 2013 McQueen #68
50 Fahrenheit + is great. Lower than that for me equals more gear. Do not ride below freezing.
ArmyVet is offline   Reply With Quote
Old 11-24-2012, 09:52 AM   #4 (permalink)
Main Motorcycle: 71 Bonnie
dogtired's Avatar
Other Motorcycle: 2012 T100
When it is uncomfortably too cold to ride nood.
I'd do me...
Deuteronomy 25:11-12
dogtired is offline   Reply With Quote
Old 11-24-2012, 09:53 AM   #5 (permalink)
triumpt120rv's Avatar
I've gone -18* C. but max 60 KPH and not for very long as the fullface frosted up. As long as there is no ice on the road I will ride. I avoid drivers as much as possible because they do not expect to see a motorcycle in winter. Ideally my bike and I run best at about 0-10* C. with dry conditions. It is 0* now and sunny. Gotta go. See ya!
triumpt120rv is online now   Reply With Quote
Old 11-24-2012, 10:55 AM   #6 (permalink)
Main Motorcycle: 2005 Bonneville
SevenMonkeys's Avatar
Depends on how much gear you have. Lower than about 45 you really need something fancier than jeans and a normal jacket.
I got stuck on a rainy 40 degree ride recently and my hands about froze off using uninsulated gloves.. I stopped at a gas station and got some one-time use hand warmers that hunters typically use. Stuffed them in my gloves and felt much better.
SevenMonkeys is offline   Reply With Quote
Old 11-24-2012, 11:44 AM   #7 (permalink)
D41
Main Motorcycle: Valmoto Replica
Depends...this time of year I can leave the house when it's near 80F, and then head up into the mountains and reach the snow-line where it's bloody cold...then I know it's time to go home...or at least lower.
D41 is offline   Reply With Quote
Old 11-24-2012, 12:13 PM   #8 (permalink)
Main Motorcycle: 2009 street triple
monkey wrench's Avatar
with a heated vest and grips ill ride to 32f. after that i worry about ice on the road.
monkey wrench is offline   Reply With Quote
Old 11-24-2012, 12:22 PM   #9 (permalink)
Main Motorcycle: '06 Speed Triple
Other Motorcycle: '96 Adventurer Cafe Racer
Extra Motorcycle: Not any more
Lower 40's typically is about my lower limit. I've ridden in the 30's but it just isn't enjoyable; it becomes an endurance test by then, so why do it?
I would be happy to ride at lower temps, but I don't have any heated gear. Heck, I don't even have any winter gear - I wear the same jacket at jacket, pants, boots, and gloves at 40 as at 100, I just open everything up in the summer and add base-layers in the winter. I do have heated grips though, and they come on pretty much any time it gets down around 60 if it's not sunny out. Since they're there, might as well use 'em!
Don
'06 Speed Triple
and a bunch of other stuff
If everything seems under control, you're just not going fast enough - Mario Andretti
zelatore is offline   Reply With Quote
Old 11-24-2012, 12:33 PM   #10 (permalink)
Main Motorcycle: 2010 Rocket 3 Touring
Tripps's Avatar
Other Motorcycle: 78 CB750K, 02 Sprint
Extra Motorcycle: 80 BMW r65/sidecar
I'll ride anytime roads are dry, 27 F is the lowest I've ridden, I do have heated vest and gloves, though.
The greatest obstacle to discovery is not ignorance -- it is the illusion of knowledge. - Daniel J Boorstin
Tripps is offline   Reply With Quote
01 790 hard cold start /cold misfire kiwiraca Twins Technical Talk 6 03-14-2010 04:34 PM
So how cold is too cold? asmelot Sprint Forum 50 02-20-2010 11:01 PM
Jump Starting and cold cold temps ztolley The Rocket Science Forum 24 01-15-2010 12:25 PM
Cold Weather Riding - How Cold is too Cold? canuck3134 Classic, Vintage & Veteran 21 11-24-2009 08:19 PM
Cold Weather/Cold Tires LoVel Biker Hang-Out 6 11-19-2008 06:42 PM
