The end of under-tail exhausts? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-23-2012, 05:28 AM   #1 (permalink)
Main Motorcycle: My Street Triple R
Aysee's Avatar
Stumbled across an interesting article so I thought I'd share -
http://blogs.motorcyclistonline.com/...nce-30483.html
It seems most motorcycle manufacturers are moving away from under-tail exhausts. They never really made much sense but I still like 'em.
My garage - http://www.triumphrat.net/garage/1526
Aysee is offline   Reply With Quote
Old 11-23-2012, 05:33 AM   #2 (permalink)
Main Motorcycle: Triumph Daytona 675
jayzzz's Avatar
I know exactly what you mean. They don't make any sense, but I do love the look of an underseat exhaust. In fact I'm currently looking for a 2010-11 daytona 675 to replace the Sprint ST 1050.
Yep, I have a thing for them.
jayzzz is offline   Reply With Quote
Old 11-23-2012, 06:25 AM   #3 (permalink)
Main Motorcycle: Speed Four
spank86's Avatar
Other Motorcycle: HMS ThunderAce
They have only one plus point. They're cool.
Everything else about them is negative and detrimental.
Still I tend to think cool wins out most of the time but it's never too bad a thing when fahsions change, theres nothing less cool than something everyones got.
Ever thought this forum might be a lot less random if any of us actually read the contents of each others posts?
You don't have to be stupid to be wrong, and you don't have to be wrong to be stupid.
spank86 is offline   Reply With Quote
Old 11-23-2012, 07:36 AM   #4 (permalink)
Main Motorcycle: 2001 Bonneville
Irishguy's Avatar
Other Motorcycle: 1999 Yamaha TW200
It's natural for us to like under tail exhaust because we are built that way too...
Irishguy is offline   Reply With Quote
Old 11-23-2012, 08:09 AM   #5 (permalink)
triumpt120rv's Avatar
I'm really diggin this style but will probably see it more and more.
Old 11-23-2012, 09:03 AM   #6 (permalink)
Far from cool! In our summer months (November thru April), the amount of heat that radiates off the rising link pipe on my Daytona 675 literally begins to fry my inside leg. I for one am glad the fashion is changing...
DeanRider is offline   Reply With Quote
Old 11-23-2012, 03:25 PM   #7 (permalink)
Not bad Irish.
Old 11-23-2012, 04:32 PM   #8 (permalink)
Main Motorcycle: 07 Bonnie Black
Kirkus51's Avatar
They definitely raise the center of gravity.
Kirkus51 is online now   Reply With Quote
Old 11-24-2012, 01:54 AM   #9 (permalink)
UnklFungus's Avatar
I dig the exhaust on the Kawasaki Versys and now the Panigale has a version of it. Down low at the bottom of the bike. The Panigale raised the level of quality in the looks department substantially tho.
Versys
Panigale
Videat veritatem
See the truth
UnklFungus is offline   Reply With Quote
Old 11-24-2012, 02:27 AM   #10 (permalink)
Main Motorcycle: 71 Bonnie
dogtired's Avatar
Other Motorcycle: 2012 T100
While at Barber hob knobbing with the Triumph blokes on the Monday after the vintage event, they had a 2013 Daytona R there, had a low exhaust on it, was still being developed though, it was just the inner skin, didn't have the outer on it yet. I was told it was still under development.
EDIT: - Just found a 9 day old pic of it on a search...
With all the changes, the Daytona 675 and 675 R are 3-lbs. lighter than the 2012 wet weight of 407 lbs., and have two extra base horsepower, bringing the max power up to 126 hp @ 12,600 rpm.
Speaking of the new engine, Triumph says "the key change is the wider bore and shorter stroke dimensions, allowing a higher 14,400rpm rev limit to gain more power and a broader spread of usable revs. Facilitating this is the new block, separate from the upper crankcase and with ceramic coated aluminum bores so it can be made stronger to cope with the higher pressures. Power is up 2bhp to 126bhp, peaking earlier at 12,600rpm and revving on for longer. The torque maximum is 2ft.lbs higher at 55.3lb.ft, with an increase across the rev range."
Also aiding in this increased power are new twin injectors per cylinder, reshaped titanium valves that allow for higher revving, a larger intake that flows "air straight into the center of the bike, right through the headstock, and as a major bonus this increases the quality and volume of the signature three-cylinder snarling intake roar for the rider."
Gotta love intake manifold roar.
Interesting...
Source.
I'd do me...
Deuteronomy 25:11-12
dogtired is online now   Reply With Quote
Low Boy Exhausts & Tail Tidy's to Consider Zoomzoommo Street Triple Forum 2 08-25-2011 12:01 AM
D675 Tail Swap for Street Triple Tail nitemask Maintenance & Workshop Talk 0 05-01-2011 08:08 PM
Are Trident Exhausts Wolf exhausts? Redd_Daetona Daytona Deliberations 3 02-05-2009 03:51 AM
What tail light with race tail? GNTurbo6 Triumph SuperSports 3 07-15-2008 12:25 AM
Hard Tail or Soft Tail for New Bonneville MaxH Maintenance & Workshop Talk 11 04-29-2005 09:49 AM
