"Other" parts that fit our bikes - Page 12 - Triumph Forum: Triumph Rat Motorcycle Forums
 5Likes
post #111 of 169 (permalink) Old 01-16-2013, 02:45 PM
Newbie
Main Motorcycle: Triumph T-100 2010
Other Motorcycle: BMW R65LS 1984
Extra Motorcycle: BMW R850R 1997
Bonnie fuel sensor
The low fuel sensor on my '10 Bonnie may be bad - is there any cheaper substitute part? The OEM sensor is about $200 (ouch!) Haven't cracked open the tank for the fuel filter change (but it is time) and would like to kill two birds with one stone. Or is there a procedure to test/clean out the sensor?
Note: the light is working, it comes on at the initial system start then goes off, but won't light up for low fuel. But on the other hand, I found out that it takes just over 3.7 gals to fill an empty tank. And another interesting thing - fuel starvation occurs sooner while going downhill.
kenhuie is offline
post #112 of 169 (permalink) Old 01-21-2013, 12:01 PM
Main Motorcycle: 2012 T100
honmaguro's Avatar
Originally Posted by DUG View Post
Hi
I put the original bars of my 07 Roadking & a set of HD nostalgic grips on my 04 T-100 recently. I think they don't look out of place, and the mirors don't look as dickie, (they're still going tho).
Whata ya recon?
PS: you have to trim the inside of the houseing a wee bit to fit the grips.
I purposly left it a wee bit close, now I have a cruise control, and my hand (which has been broke a few times thanks me)
Cheers
Those look great - comfortable?
honmaguro is offline
post #113 of 169 (permalink) Old 01-25-2013, 09:23 AM
Main Motorcycle: Triumph Thruxton
Lord Iron Bar's Avatar
Other Motorcycle: Why??
Master cylinder
Great post!! Any solution for the poor >2010 Thruxton's Brake Master Cylinder? I'd like to upgrade with a radial with bigger diameter
Info: I've upgrade to a 3 pots Nissin gold caliper and need overtighten levers to brake.
Thanks in advance
Lord Iron Bar is offline
post #114 of 169 (permalink) Old 02-13-2013, 09:48 AM
Main Motorcycle: SPEED TRIPLE 1050
Rayzor61's Avatar
Other Motorcycle: T Explorer 1200
Extra Motorcycle: 09 Bonneville Tracker
I put 2011 Speed Triple mirrors on the Bonneville Mag to replace the stock lolipops. Also, I used the stock S3 bar ends as hole filler caps on the pillian peg bracket after removal. They fit perfectly and look trick.
Also put a 160/60/17 Pirelli MT60 (4.5" tire) on a 3.5 inch Bonneville mag which calls for a 130/80/17 3.5 inch. There is no sidewall bulging and looks fat and sweet!
Buy as many bikes as you can before you die, and try to live!
Rayzor61 is offline
post #115 of 169 (permalink) Old 03-03-2013, 11:34 AM
Main Motorcycle: Thruxton 900
lordyama_vdc's Avatar
Other Motorcycle: cb450t Hawk
Correct me if I'm wrong. Regarding all this foot peg hub bub. Isn't the problem with the oem Triumph pegs with the clevis bolt sheering off? So technically swapping out for these YZF pegs is still leaving you with the same possible issue?
lordyama_vdc is offline
post #116 of 169 (permalink) Old 03-05-2013, 12:12 AM
Main Motorcycle: 2001 Bonneville
Fuse block terminals
It has probably been covered, but over in the sprint forum a crimp terminal has been found that fits inside all the modern triumph fuse blocks:
http://www.triumphrat.net/maintenanc...ml#post2522277
So if you're like me and it was starting to look like a rats nest of wires and fuses under your seat from all the mods, here is a cheap and easy way to clean it up, if you have blanks in your fuse block.
TL; DR: the 3-8331, 3-8332 and other wire gauge terminals from Vehicle Wiring Products UK are an acceptable fit, with a quick and minor adjustment.
schuitz is offline
post #117 of 169 (permalink) Old 03-06-2013, 02:12 AM
Main Motorcycle: 06 bonneville hardtail
o4petesake's Avatar
Other Motorcycle: looking
I think Newbonneville.com sells one
o4petesake is offline
post #118 of 169 (permalink) Old 03-13-2013, 11:47 PM
Main Motorcycle: 05 Triumph Thruxton
Kawasaki ZRX 1100 and 1200,
Anyone know if ohlins from these models will fit a thrux....?
RandyD is offline
post #119 of 169 (permalink) Old 03-14-2013, 09:23 PM
Those use a 43mm fork leg where as Thruxton uses 41mm. You can fit em but you would need:
New triple clamp
Axle adapter
Brake caliper adapter
May have to adjust fork legs in triple clamp to regain factory geometry.
Fruxton Stu is offline
post #120 of 169 (permalink) Old 03-25-2013, 05:51 AM
Main Motorcycle: Triumph Legend -01
Other Motorcycle: No need.
Cool Speedmaster
I have a -07 Speedmaster and I didn't like the cast wheels. So I bought hubs, rims ans spokes from CWC in Birminham UK. Its the same hubs as on Tiger and (3 cylindre) Thunderbird Sport in front (both have twin-discs), and included America in rear. Everything fits right on!
I had to adjust my front mudguard mounting holes a bit since I went up to 19" in front.
I bought a hub for a Thunderbird sport for the front wheel. I think it looks better. Its a slightly difference in the area where the spokes are inserted. The Tiger is more "off-roadish" if you ask me.
I have a 180/55-17" rear tyre and there is plenty of room.
JohnSpeedmaster is offline
Combining my "seat heat" and "tune" threads here TheNomad Sprint Forum 10 06-02-2008 01:09 PM
Bikes with "faces" could be safer GixxerMeThis Biker Hang-Out 12 03-15-2008 12:53 AM
Possibly the only episode of "Super Bikes" ever worth watching Mattrat Biker Hang-Out 5 10-04-2007 03:27 PM
"BIKE" Magazine article of top 150 bikes ricster Sprint Forum 18 07-30-2007 11:07 AM
