Can a bike run without a battery? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 13 (permalink) Old 11-10-2008, 11:58 AM Thread Starter
Main Motorcycle: 2007 Bonneville T100
Kramocker's Avatar
Other Motorcycle: 04 Yam V-Star 1100 (Hers)
I apologize in advance. This is a question about my wife's V-Star. It's been hard to start lately. The battery is obviously weak. We hadn't ridden for a while because it's been too friggin' hot. I start it weekly. It cranks slowly buy eventually catches and fires. I took it out yesterday and it died several times. Felt like it was starving at higher rev's then died at stop signs. I had to leave the key off for about five minutes before it had enough juice to start, I eventually got it home and let it idle for a bit in the garage. After that it would start instantly. Bad battery? I thought that once it was running you could pull the battery out. Of course...I guess the headlight/tail light/brake light might be a factor.
Thanks in advance.
Cheers,
SK
2007 T100 T&O - AI's off, ARK, K&N's, 42 pilots, 140 mains, 2 turns out, D&D silencers, ACR Adjustable Clubman's, KYB's, WP springs, Thrux gel seat______________________________________________
Who's that little old man with Paul?
Kramocker is offline
post #2 of 13 (permalink) Old 11-10-2008, 12:19 PM
Motorcyclist
Supernova
Main Motorcycle: 2013 Tiger 800XC
propforward's Avatar
Other Motorcycle: 2007 Bonneville, ST1300
Extra Motorcycle: G12DL, ZX1100, KLX400
On modern bikes you need a battery in the circuit for it to run. A shorted battery will not let the bike run.
Old bikes you used to be able to run without a battery I think.
Before he did it, I'd have said it couldn't be done.
propforward is offline
post #3 of 13 (permalink) Old 11-10-2008, 12:56 PM
Main Motorcycle: Newchurch
Pokeyjoe's Avatar
Bring back magnetos!
John
3-7-77
Pokeyjoe is offline
post #4 of 13 (permalink) Old 11-10-2008, 01:34 PM
Motorcyclist
Supernova
I'll get my Lucas K2F on my Bonnie post haste!
post #5 of 13 (permalink) Old 11-10-2008, 02:22 PM
Main Motorcycle: Scrambler!
reflectedstatic's Avatar
Other Motorcycle: Waterford F-22 (acoustic)
Just drag the battery to a chain auto parts store, get them to hook it to the machine, and they should be able to tell you pretty quickly if something major is wrong with it. If it's not that, check the voltage regulator, since most dead alternators are actually dead voltage regulators. If it's not that, start to look elsewhere.
To answer your question though, in theory, it is not necessary to have a battery in an alternator-powered electrical system once the engine is running. The battery is absolutely necessary to power the field windings while the engine is starting, which is why you can't bump or kick start a bike with an alternator if it has a dead battery, but IF there's never more current drawn than is being produced, a battery is not strictly necessary once the engine is running. That's a big 'if', though, because most bikes' alternators don't keep up with current draw at low RPMs, making a battery necessary to fill in the gaps.
Of course, if the battery has an internal short, all bets are off.
reflectedstatic is offline
post #6 of 13 (permalink) Old 11-10-2008, 03:26 PM
Send a message via AIM to CAPTDON
Battery
My exp has been NO the bike will not run w/o a battery or w/ a dead one! I GUESS if you could kill the lights & all it might run if its warmed up, but forget pop starting it! Just bought a cheap little 150 Chinese scoot to get to the Bonne garage. 1 thing I really like @ it IS- the headlights etc wont work unless the scoot is running! MAkes starting a bit easier w/ a soso battery! As said MAGNETO!!!
CAPT D
CAPTDON is offline
post #7 of 13 (permalink) Old 11-10-2008, 07:54 PM Thread Starter
Kramocker's Avatar
I love this forum!
I just wanted to thank everyone who responded. Now all I need to do is FIND the battery and then it's off to Auto Zone.
Cheers,
SK
post #8 of 13 (permalink) Old 11-10-2008, 08:10 PM
Motorcyclist
Supernova
That all depends how the system is set up. On most bikes these days, the battery is part of the circuit such that the bike won't run without it, whether under minimal load, lights off, disconnected once running or whatever. As you say - a shorted battery certainly won't work.
post #9 of 13 (permalink) Old 11-11-2008, 01:23 AM
Very true. I don't know how a V-star is wired, and now that you mention it, it's probably not possible on a modern Triumph twin either. Obviously anything with EFI is dead in the water. Yet another example of "theoretically", "practically", and "realistically" being three completely different things.
FWIW, I did push start my '50 Ford once (with the help of a really big hill) when it had a completely dead battery. It ran a generator instead of an alternator, though. I imagine that the same could be done with a bike if you could find a bike that runs a generator. It's definitely possible to push start anything that runs a magneto. If only it were worth it otherwise...
In conclusion, magnetos for all! (shudder)
post #10 of 13 (permalink) Old 11-11-2008, 06:50 AM
Motorcyclist
Supernova
Yes indeed - the older stuff was set up such that the electrickery generator could power the whole system. I assume that was because batteries were still a bit iffy in those days - or maybe that's just how they felt like doing it at the time.
Bike won't run with completely dead battery. cw Air Cooled Twins Technical Talk 5 07-29-2008 01:46 PM
New Bike & Dead Battery? Winfield Maintenance & Workshop Talk 1 06-01-2008 12:30 AM
Dead Battery on New Bike hhuffman Daytona Deliberations 12 05-11-2007 09:55 AM
Bike Storage- Battery Dilemma chip0704 Sprint Forum 16 12-04-2006 04:18 PM
Bike quit? Check the battery connections. Sprint Forum 3 10-15-2004 11:24 PM
