Engine Removal/Frame Dissasembly - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 21 (permalink) Old 09-10-2008, 05:43 PM Thread Starter
Main Motorcycle: 07 Triumph Scrambler
justbrian's Avatar
I've got a quick question for those who have removed their motors for case machining, frame alterations, etc.
I'm leaving out MANY steps in between, but the factory service manual recommends removing the rear swing arm, dropping the lower frame subsection from the bike (with the motor still attached to the top fore and aft mounts), and THEN lowering the motor from the bike.
My instinct says it would be easier to disconnect the top motor mounts and drop the lower frame subsection with the motor still attached, without removing the rear swing arm so the bike can still sit on two wheels. Then I could place the motor on a pallet/cradle and dismount the lower frame subsection.
How did you do it? Clearance issues with the swinging arm if I did it my way?
Thanks!
justbrian is offline
post #2 of 21 (permalink) Old 09-10-2008, 07:21 PM
Motorcyclist
Supernova
Main Motorcycle: 2013 Tiger 800XC
propforward's Avatar
Other Motorcycle: 2007 Bonneville, ST1300
Extra Motorcycle: G12DL, ZX1100, KLX400
Doesn't the pivot shaft for the swingarm go through the engine casings? I think you have to pull the engine and then put the swingarm back in. But there may be some trick I'm not aware of.....
Before he did it, I'd have said it couldn't be done.
propforward is online now
post #3 of 21 (permalink) Old 09-10-2008, 07:33 PM Thread Starter
justbrian's Avatar
After giving the bike a good "second look", your right!
Thanks.
post #4 of 21 (permalink) Old 09-11-2008, 06:44 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
yea it goes through the motor but you only have to pull the bolt if your carful after you get the motor off you can put the bolt back in and move the bike around on its wheels just watch the chain.
mikeinva is online now
post #5 of 21 (permalink) Old 09-11-2008, 07:30 PM
Legend
Main Motorcycle: 904cc Bonnie w/magwheels
sweatmachine's Avatar
Send a message via AIM to sweatmachine
I put my bike on the craftsman bike jack, and after taking off the seat, gas tank, exhaust, carbs, etc I removed the swingarm, rear wheel, and shocks, all in one piece (heavy as hell!!!):
Then, I unbolted the lower section of the frame, and lifted the main part of the frame right off the motor:
Sorry for the crappy cell phone pics, here's me riding my "bobbed" bike. I took a lot of weight off it, but the power to weight ratio sucked:
When I put it back together I just put the frame right back on top of the motor. Simple!
sweatmachine is offline
post #6 of 21 (permalink) Old 09-11-2008, 10:17 PM Thread Starter
justbrian's Avatar
Nice - thanks guys!
post #7 of 21 (permalink) Old 09-11-2008, 11:01 PM
Main Motorcycle: None don't ride anymore
Hey Sweat,I`m thinking about making a single downtube section from the front lower motor mount upwards.If both lower rails were fixed together as a single piece,could they still be removed if I needed to,or do the 2 rails need to move outward to be removed?
rodburner is offline
post #8 of 21 (permalink) Old 09-11-2008, 11:20 PM
Legend
A single downtube would work.
post #9 of 21 (permalink) Old 09-11-2008, 11:24 PM
Cool,Thanks
post #10 of 21 (permalink) Old 09-12-2008, 12:37 AM
Main Motorcycle: Two wheeled
Retro-Racer's Avatar
Other Motorcycle: several
Extra Motorcycle: next one
The floor jack method works just fine. If you are stripping the bike down to the frame, I'd obviously would remove the front end before separating the frame.
Take lots of digital photos and bag & lable everything. If you want to pull the bottom frame rails, you can carefully roll the bare motor over upsidedown onto a shipping blanket and remove the rails.
/Mike
Retro-Racer is offline
Frame Engine numbers dennisg Classic, Vintage & Veteran 11 07-24-2009 02:27 PM
Frame Finishers - Rear foot peg removal. faffyface Speed Triple Forum 4 05-09-2008 03:58 PM
engine and frame numbers meangene1975 Classic, Vintage & Veteran 4 04-15-2008 10:01 AM
B50 Engine in Triumph frame SoupDragan Classic, Vintage & Veteran 1 02-03-2007 10:59 AM
Engine and frame numbers Soccermasta Air Cooled Twins Technical Talk 2 08-28-2006 10:08 PM
