Great source of info - Links to maintenance, tuning, modifications and so on - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
post #1 of 29 (permalink) Old 07-30-2008, 10:07 PM Thread Starter
Administrator
Legend
Main Motorcycle: Tiger 955i
Haggis's Avatar
Other Motorcycle: Sprint RS
Extra Motorcycle: Honda XL250
Thumbs up Great source of info - Links to maintenance, tuning, modifications and so on
MODERATOR NOTE:
This sticky is posted to provide an easy means to scan for frequently required "how to" information. Links to threads containing info on modifications, tuning, maintenance and so on can be posted here.
Posts will be continually consolidated to keep the thread easy to scan, so do not be offended if your actual post is deleted, the link will have been copied to another post in the thread.
Also, no comments please. These will be removed. Thanks and best wishes!
To start, a collection of info gathered by Keef:
http://www.triumphrat.net/blogs/twin...-mod-links-35/
Twins documentation library general link:
http://www.triumphrat.net/blogs/twin...ion-library-7/
Triumph Owners Manuals:
http://www.triumphmotorcycles.com/of...rvices/manuals
Haggis is offline
post #2 of 29 (permalink) Old 08-14-2008, 04:06 PM
Motorcyclist
Supernova
Main Motorcycle: 2013 Tiger 800XC
propforward's Avatar
Other Motorcycle: 2007 Bonneville, ST1300
Extra Motorcycle: G12DL, ZX1100, KLX400
Air / Fuel gauge installation plus Carb Tuning
Great source of info for anyone considering tuning their bike:
A/F gauge Install/Data:
Ventura's Install
Ventura's Data
Kframe install and data
Bonniebobs original thread, that started it all
General info on how carbs work, and tuning
Jenks Bolts Tuning Guide
Pat Dinquas Rejet Guide
Retro-Racer's Rebuilding stock carbs with pics
Pics of How Jets Fit
Main and Pilot Jet settings for different mods
Carb Tuning Guide
Discussion on rejetting carbs, and overcoming the difficulties therein
Pilot jet and mixture screw setting
Carburettors
Carburettor Discussion
Dynojet vs Thrux needle comparison
FCR39 carb tuning / setup
FCR 39 overview and review
Before he did it, I'd have said it couldn't be done.
Last edited by BonnieBlack; 09-30-2015 at 05:41 PM. Reason: remove bad links, Add Retro-Racer's link
propforward is offline
post #3 of 29 (permalink) Old 08-14-2008, 04:37 PM
Motorcyclist
Supernova
Links to Oil Discussions and info
TriumphRAT threads on oil - lots of discussion, some of the threads have external links that are of interest. Hopefully this makes the discussion easy to find - not that it isn't fun discussing oil all over again!
http://www.triumphrat.net/twins-tech...synthetic.html
http://www.triumphrat.net/twins-tech...o-you-use.html
http://www.triumphrat.net/twins-tech...-oil-talk.html
External Links
http://motorcycleinfo.calsci.com/Oils1.html
http://www.shellusserver.com/ubbthre...age=1#Post3081
Oil Filter Dissection
http://www.triumphrat.net/twins-tech...with-pics.html
Amsoil comparison of motorcycle oils:
http://www.amsoil.com/performancetests/g2156.pdf
post #4 of 29 (permalink) Old 08-15-2008, 11:20 AM
Motorcyclist
Supernova
Fitting Fork Gaiters
Step by step details by Localmotion411 plus photos. Nice work!
http://www.triumphrat.net/twins-tech...ter-fit-2.html
Another Version by Keef:
http://www.triumphrat.net/twins-talk...tallation.html
post #5 of 29 (permalink) Old 09-25-2008, 11:18 AM
Motorcyclist
Supernova
Bobbing Fenders and Bodywork Mods
http://www.triumphrat.net/twins-talk...creen-diy.html
Shruums Fender Bob and Lighting Project
post #6 of 29 (permalink) Old 10-01-2008, 11:16 AM Thread Starter
Administrator
Legend
Haggis's Avatar
Jetting
This is cut and pasted from one of Ventura's posts.
During all of the testing and modding, my Scrambler was fitted with Zard 2:1 exhaust, but the initial results were the same as with NH after-market silencers.
It seems probable therefore that any opened-up exhaust system will give comparable results.
It was also without the AI system.
It was concluded during testing that the type of filter (stock paper or Uni) made no difference to A/F ratio, so this isn't included.
All the below adjustments were made to maintain an A/F ratio of between 13:1 and 13.7:1
This being the considered optimum.
Stock exhaust with snorkel................110 / 40 / no shims / 1.5 turns
Open exhaust + no snorkel................115 / 40 / no shims / 2.0 turns
Above + Restrictor gone....................120 / 40 / 1 shim / 1.0 turns
Above + enlarged filter inlet...............130 / 40 / no shims / 1.75 turns
Above + RHS opened up....................135 / 40 / no shims / 2.0 turns
Above + velocity stacks.....................145 / 40 / no shims / 2.5 turns
With ARK + good pod filters............. >145 / 40 / no shims / 2.5 turns
I hope all of this will be of help as a guide to others who are endeavoring to determine correct jetting following basic modding of the air intake.
Hopefully, as others carry out the A/F gauge install, these figures can in the future be added to / amended / or maybe even totally contradicted!!
More lively discussion to look forward to!!
For reference, Keihin vs Dynojet equivalence. Jets in above table are Keihins:
Keihin ----- DJ
110 ------- 106
112.5 ----- 108
115 ------ 110
117.5 ----- 112
120 ------- 114
122.5 ------116
125 ------- 118
127.5 ------120
130 ------- 122
132.5 ------124
135 ------- 126
137.5 ----- 128
140 ------- 130
142.5 ----- 132
145 ------- 134
Last edited by propforward; 10-12-2008 at 09:18 AM. Reason: added Keihin vs DJ table
Haggis is offline
post #7 of 29 (permalink) Old 10-06-2008, 09:01 PM
Motorcyclist
Supernova
post #9 of 29 (permalink) Old 11-07-2008, 08:23 PM
Motorcyclist
Supernova
post #10 of 29 (permalink) Old 11-08-2008, 08:38 AM
Motorcyclist
Supernova
Carburetor Tuning: Anyone recommend a good Carburetor tuning manual? FrankBlack Maintenance & Workshop Talk 0 05-23-2008 12:10 PM
Keihin FCR 39: looking for diagram & tuning info Never Bored Air Cooled Twins Technical Talk 13 01-11-2008 08:23 AM
Great source for replacement metal dry brake fittings whodkne Speed Triple Forum 2 04-02-2007 04:27 PM
rocket cleaning info/clarification of mis-info soberdude The Rocket Science Forum 14 10-27-2006 11:30 AM
Great...just Great. Dropped it right in the driveway. FALSTEN Sprint Forum 7 07-30-2006 05:34 PM
