Air intake mods...... Definitive results - Page 21 - Triumph Forum: Triumph Rat Motorcycle Forums
post #201 of 212 (permalink) Old 11-29-2012, 03:14 PM
Main Motorcycle: Thruxton
georider's Avatar
Other Motorcycle: Yamaha Roadliner
Extra Motorcycle: Yamaha R1 2015
Ah! This is an high performance airbox intake from an husqvarna TC 250R
There it is, the "reverse" bell mouth.
georider is offline
post #202 of 212 (permalink) Old 11-29-2012, 07:15 PM
Main Motorcycle: Two wheeled
Retro-Racer's Avatar
Other Motorcycle: several
Extra Motorcycle: next one
Suck on this.... errrr... these!
/M
"With integrity, nothing else matters. Without integrity, nothing else matters."
Retro-Racer is offline
post #203 of 212 (permalink) Old 11-29-2012, 09:30 PM
Main Motorcycle: Yes
B02S4's Avatar
Originally Posted by Retro-Racer View Post
Suck on this.... errrr... these!...
Pity they have chrome-cap K&N's, eh?
B02S4 is offline
post #204 of 212 (permalink) Old 04-16-2013, 08:36 AM
Main Motorcycle: 2002 Bonneville America
Texstrom's Avatar
Other Motorcycle: 1996 Thunderbird
Extra Motorcycle: 71 BMW R75 (Project)
Originally Posted by Forchetto View Post
It's a sound control device loosely slotted inside the airbox. Its purpose is to reduce the intake roar noise although it also robs you of around 3 hp. To recover those hp, carbed bikes need re-jetting and EFI bikes need re-mapping of the ECU as well as air intake snorkel removal.
It's the yellow thing shown here:
Removal instructions and an explanation of its purpose are all over this forum and also at
TTP's site:
http://www.triumphtwinpower.com/triu...le-removal.php
Could one not compensate for the "lean runnning " by adjusting the pilot screws? Is a re -jet absolutely necessary? I just am reluctant to get into carbs and the mystery of corect jets etc.
Texstrom is offline
post #205 of 212 (permalink) Old 04-16-2013, 08:47 AM
Main Motorcycle: Rebuilt 1993 Trophy 900
alexibrow's Avatar
Simply put:
The pilot screws adjust the air/fuel mixture at/just off idle.
Needle height affects the mixture around mid throttle openings.
Main jet size affects the mixture at full throttle.
This is an oversimplification, but in general you won't normally get away with adjusting just one fuel circuit if you make significant changes to the intake and/ or exhaust systems.
Sent from my GT-I9001 using Motorcycle.com App
alexibrow is offline
post #206 of 212 (permalink) Old 07-28-2013, 11:43 PM
Main Motorcycle: 2006 Scrambler
strafkommando's Avatar
Other Motorcycle: 1981 KZ440 LTD Belt Drive
Extra Motorcycle: 1973 CB350G
well this thread should never die. after heavy searching in the forum and reading a good deal of Ventura's, Pieman's, and Forchetto's post (for months) I finally got to work on my 2006 Scrambler. got a 12 pack and spent Saturday in the garage. pulled the baffle from the airbox, installed new idle mixture screws ( had to fashion a homemade fitting to get the d screws out), put in a TTP breathe bellmouth and DNA filter, threw in 135 mains with the stock 40 pilots, and put on D&D slips ons. Im at 1.75 turns on the idle mixture screws but not totally sold on that setting yet.
Im extremely happy with the results but it is difficult to do this many things at once and decide how to adjust. The stock scrambler needles are in now with one shim but I have thruxton needles on the way. The top end pulls evenly all the way to 100mph (and quickly) I think after reading enough about other peoples trials I got pretty close first try.
two questions.
1) I didn't pull the baffles from the d&d pipes but they seem pretty open and flow a lot of air. with jetting and intake mods of this nature should I pull them or leave them be if the bike is running well and it sounds good to me??
2) I feel as if I may of gotten close to nailing the settings with the stock scrambler needles with one shim. when I put in the thruxton needles should I start with no shim?
strafkommando is offline
post #207 of 212 (permalink) Old 07-29-2013, 11:07 AM
Main Motorcycle: 08 Bonnie carbed
racerdave1's Avatar
Other Motorcycle: 2010 HD RoadGlide
Are the Truxton needles richer,leaner or the same as 08 Bonneville needles?
racerdave1 is offline
post #208 of 212 (permalink) Old 07-29-2013, 11:41 AM
Main Motorcycle: 2009 Blue & White America
MattyMo's Avatar
Originally Posted by strafkommando View Post
two questions.
1) Leave them for now as it runs well and sounds good to you. If you need more air flow later you have those baffles you can pull!
2) Can't help on that one. Really need to on a dyno for that type of "fine" tuning I would think.
I think they just have a slightly different taper at the end.
If someone knows more please speak up.
2009 America with some mods, a lot of fun that I can ride all day. (sold and miss my 2008 Bonneville, a great daily driver)
this message was created using recycled electrons
MattyMo is offline
post #209 of 212 (permalink) Old 07-29-2013, 12:55 PM Thread Starter
Main Motorcycle: Can't decide now!!
Ventura's Avatar
Other Motorcycle: Scram
Extra Motorcycle: '16 Yam XSR900
The Thrux needles are richer than standard.
Here's an dyno A/F trace comparing the two. The richer one is the Thrux needle....
V.
2006 Scrambler, VARK'd, FCR39's & DNA's, 790 In-cam, Pieman'd igniter, Zard 2:1.
Ventura is offline
post #210 of 212 (permalink) Old 07-29-2013, 01:14 PM
Ventura i think i saw you post that on another thread which is what made me grab some thrux needles anyway . from my understanding the shim usually richens the mix as well (i believe). that being said with the thrux needles ill start with no shim and leave the baffles in the D&D pipes for now. see how that feels. tinker with my idle mix screws on the low end then maybe shoot for a dyno run.
the help is much appreciated. i only get about 6 days a month with my bike so its harder to do things trial and error
Sent from Motorcycle.com Free App
Dyno results after mods Crazy8 Club Cafe' 35 04-21-2008 05:15 PM
Want to buy a 790 intake cam Blacklion50 Air Cooled Twins Technical Talk 1 09-27-2007 09:13 AM
Definitive Answer calliperman Speed Triple Forum 3 11-14-2006 12:33 PM
definitive indoor storage customcafe Club Cafe' 8 12-12-2005 07:33 PM
Definitive differences between 00-01 vs 02-04 RS OKAggie Sprint Forum 27 04-23-2004 12:25 PM
