Air intake mods...... Definitive results - Page 19 - Triumph Forum: Triumph Rat Motorcycle Forums
post #181 of 212 (permalink) Old 11-05-2012, 09:30 AM
Main Motorcycle: Thruxton
georider's Avatar
Other Motorcycle: Yamaha Roadliner
Extra Motorcycle: Yamaha R1 2015
Great post, PieMan.
when I bought my Thruxton, I got thrown in the deal a set of TOR exhausts and a K&N filter.
I didn't get the filter immediately, I got it some time later when I got the time to swing by the dealer and collect it.
When I got around to installing it, I noticed that only about half of the the OEM filter had "dirt" on it, right about where the snorkel ends.
That was the start of my mechanical "what if..."
what if I removed the snorkel?
what if I removed the air box?
Then I rode a EFI Thruxton with pod filters, Arrow exhausts, Re-map, the works.
Truth is, although in high revs it pulls much, much harder than mine, it isn't as nice to ride around town.
One doesn't get the feeling of a better, higher performing bike. It feels more like a dedicated racer's bike.
So, like I'm sure many others, I don't really know what my future performance up-grade will be. I mean, the bike is fine for what it is, but if I were a snorkel removal away from an extra hp...
georider is offline
post #182 of 212 (permalink) Old 11-05-2012, 02:06 PM
Main Motorcycle: The One I Gots
LukiSevenAce's Avatar
Other Motorcycle: Only This One Now
I wonder if anyone knows (offhand) how much Triumph invested in devising the optimal system for intake through to exhaust on the modern Bonnevilles.
Just curious.
Would think they had to spend -at least- a couple hundred thousand dollars/pounds/shekels designing, prototyping, testing and revising the whole kit and kaboodle.
Must have had twenty to thirty qualified engineers hammering away at it before bringing it to market.
Of course, they have bean counters looking over their shoulders focused on maintaining a price point for the package.
Not to mention, some experts in acceptable standards for various countries the bikes would be offered in.
I've not seen it published anywhere (the numbers.)
Maybe someone here has access to the inner workings of the Company, or actually work for it (either in the UK or here in the US.)
It's an interesting proposition; in consideration of the difference between infrastructure investment of a multinational, multimillion dollar Corporation and what a Shade Tree operation has going for it.
You know, balancing it all out in a kind of perspective.
Failing, of course, to even mention the 'weird science' aspect.
Pipe right in. Enquiring mind wants to know.
LukiSevenAce is offline
post #183 of 212 (permalink) Old 11-05-2012, 02:16 PM
Forchetto's Avatar
Of course the Factory's engineers could design intake and exhaust systems for optimum power far better than anybody, given the resources, skills and money available.
The trouble is that they're presented with all the constraints of eliminating noise and reducing emissions according to present and coming regulations as well as minimising fuel consumption.
They're further handicapped in the Bonnie's case by the old fashioned layout of a full cradle tubular frame housing a relatively massive engine and carbs (or EFI equivalent). There just isn't enough space to house more than a rudimentary envelope for an air filter element in what's in effect an intake silencer box. Look at bikes that used this classic layout from the 50's and 60's. Most didn't even have an air filter and only a tiny battery (no electric starter, etc).
Witness the tiny and often proved inadequate battery they are obliged to fit through lack of space.
Forchetto is offline
post #184 of 212 (permalink) Old 11-05-2012, 03:21 PM
georider's Avatar
Right!
based on an expert advice (thanks dad!) I'll try to fabricate this:
Using the biggest part possible of the air horn, I'll make a bell... exit.
The bell will go (hopefully) inside the air box.
Something like this: (foto Forchetto)
Apparently this contraption slows the air as it enters the air box thus increasing the pressure
I know it looks silly but, hey, it's a free mod and it comes highly recommended.
The red plastic horn is easy to sand, cut and/or deform (via heat) to any shape.
I know if I it give a cool sounding name, the placebo effect will be tremendous.
I'll call it "high pressure intake super flow master air velocipressuriser"
I'll give it a go.
Now, where did I place the football (soccer) horns?
georider is offline
post #185 of 212 (permalink) Old 11-05-2012, 04:53 PM
Main Motorcycle: Scrambler
Other Motorcycle: Ducati 1198R
Extra Motorcycle: no such brand
Absolutely, manufactures must stay within the acceptable emission and noise constraints of the current standards and still produce acceptable power. This is exactly why Triumph ditched the carburetors for EFI. Less intake noise, more efficient A/F metering for various conditions.
This however doesn't suggest the engine is running at peak effeciency or can't be modified to run more optimally.
ShaneDuc is offline
post #186 of 212 (permalink) Old 11-05-2012, 04:59 PM
Forchetto's Avatar
Absolutely. It's the same with car or bike EFI tune maps. If you're going for maximum power disregarding anything else a tuner can create a good map in days. However to keep within all the regulations, noise emissions and vibration levels, aceptable fuel consumption, driveability, reliability, etc I'm told it takes many engineers months to achieve a suitable map.
post #187 of 212 (permalink) Old 11-05-2012, 07:15 PM
Gary_spain's Avatar
Other Motorcycle: Rieju Tango
The whole history of the motorcycle, not to mention the cafe racer scene, has been hinged around "shade tree operations" ever since it's conception. Some of the most advanced chassis designers, suspension manufacturers, and engine tuners have come from modest machine shops and diminutive engineering companies. It's what it's all about.
07 Thruxton: TEC 2 into 1, K&N, TTP Breathe Bellmouth, 135 mains, 40 pilots, std. needles, 1 shim (0.65mm). All baffles removed. Bitubo Fork Cartridges. Bitubo Rear Shocks. TEC Steering Damper. 3 Pot Nissin (Honda) brake caliper.
Gary_spain is offline
post #188 of 212 (permalink) Old 11-06-2012, 02:09 PM
georider's Avatar
I'm sort of going on a "mythbuster" crusade here.
I'm making the former described contraption (yes, really) and obviously some sort of means to measure results is needed.
I thought of using an Android app that registers acceleration, speed, time etc.
I'll be accelerating to the ton several times to get an average with the snorkel, without it and with the "high pressure intake super flow master air velocipressuriser". Ok, the reverse bell mouth.
Stupid?
georider is offline
post #189 of 212 (permalink) Old 11-06-2012, 02:19 PM
Main Motorcycle: Bonneville America
grzegorz's Avatar
Other Motorcycle: 2001 Bonneville Custom
what app is it?
grzegorz is offline
post #190 of 212 (permalink) Old 11-06-2012, 02:31 PM
georider's Avatar
Originally Posted by grzegorz View Post
what app is it?
It's "Smart Speedometer"
Add free, 140KB
Hummm... I think we're getting a major breakthrough here.
If all of us used the same app to record performance, we could easily compare results and graphs.
georider is offline
Dyno results after mods Crazy8 Club Cafe' 35 04-21-2008 05:15 PM
Want to buy a 790 intake cam Blacklion50 Air Cooled Twins Technical Talk 1 09-27-2007 09:13 AM
Definitive Answer calliperman Speed Triple Forum 3 11-14-2006 12:33 PM
definitive indoor storage customcafe Club Cafe' 8 12-12-2005 07:33 PM
Definitive differences between 00-01 vs 02-04 RS OKAggie Sprint Forum 27 04-23-2004 12:25 PM
