Air intake mods...... Definitive results - Page 18 - Triumph Forum: Triumph Rat Motorcycle Forums
post #171 of 212 (permalink) Old 10-20-2012, 02:03 PM
Forchetto's Avatar
Originally Posted by Lasermax View Post
Ultimately, and I've already seen it done here, is to have a set of velocity stacks going from the carbs right into the airbox, or to pods if you prefer.
I remember, a long time ago, peering inside a then new Honda CB750's airbox minus paper element filter, and seeing that it had four velocity stacks or bellmouths, made of rubber, that lived out of sight to the casual observer.
There's a new idea, for KTM's at the moment, with a combined stack and pod-type filter that's rather clever, on this post today. There's a dyno chart as well:
http://www.triumphrat.net/twins-tech...ml#post2401447
Forchetto is offline
post #172 of 212 (permalink) Old 10-20-2012, 02:50 PM
Main Motorcycle: 08 Street Triple
Lasermax's Avatar
Other Motorcycle: 2007 Speedmaster
That's awesome. Would certainly be the ticket. Thanks so much for your posts. Sakurama, what am awesome thread on ADV rider. If I don't have to take half my bike apart again, I'll be putting in stacks, with the results you've gotten, wow.
Lasermax is offline
post #173 of 212 (permalink) Old 10-22-2012, 12:02 PM
Main Motorcycle: Thruxton
georider's Avatar
Other Motorcycle: Yamaha Roadliner
Extra Motorcycle: Yamaha R1 2015
Originally Posted by PieMan View Post
GeoRider, the theories would most probably be correct if the factory snorkel was designed for performance, but it was designed to muffle the induction noise which adds something else in to the equation.
The dyno below shows the effect the Breathe has on engine performance by directly replacing the factory airbox cover/snorkel with the Breathe, with corrected fuelling. It shows a significant increase in torque in the mid range and if you remove the airbox baffle, that increase carries on to the rev limiter.
It very interesting reading this these graphs.
At high revs, 6.5 k-8.0 k, when the motor needs more air, the power and torque are the same.
What conclusion can one take from this?
georider is offline
post #174 of 212 (permalink) Old 10-22-2012, 12:42 PM
Main Motorcycle: Bonneville America
grzegorz's Avatar
Other Motorcycle: 2001 Bonneville Custom
My conclusion is that you getting more HP and torque where you need and using it most of the time
similar situation you can see here stock CDI (blue)against TTP reprogrammed one(red)
I gained there where is more usefull 3-5k
grzegorz is offline
post #175 of 212 (permalink) Old 10-22-2012, 01:53 PM
georider's Avatar
yes, you're right.
But there's not a clear relationship air port size/power.
At high revs the result is the same with a much larger hole.
grzegorz, what was your air box set up when you had the bike "dynoed" ?
georider is offline
post #176 of 212 (permalink) Old 10-22-2012, 02:45 PM
grzegorz's Avatar
on this graph internal snorkels romoved,K&N filter,Polaris belmouth run was made back to back ; run 29 CDI reprogrammed by TTP followed by run 30 with stock CDI with only rised REVs to match new unit
in the past this happened;
when I changed top snorkel(cut at the bottom) for rubber velocity stack
diffrence -----68.4hp was 67.12hp
--------------57.46ft/lbs was 54.37ft/lbs
118 main jet (four sizes up)
needle rised clip 3rd position from top
CRS carbs
grzegorz is offline
post #177 of 212 (permalink) Old 10-22-2012, 03:28 PM
georider's Avatar
Helpful post.
I'm trying to get a pattern here.
In the K&N site I got this answer:
An engine can only draw in a certain volume of air depending on the engine's size (measured by such things as bore, stroke and number of cylinders). Vehicles are designed to accommodate large changes in air pressure so they can operate at sea level or at an altitude of 14,000 feet.
Engine computers adjust the amount of fuel required as a result of changes in air pressure (density).
Air filter restriction when the filter is new and especially as the filter loads with dust will result in lower air pressure and availability similar to being at a high elevation. High-flow air filters that were invented by K&N were designed to reduce the work necessary to pull air through the filter and to increase air pressure. Increased air pressure is one of the key elements in producing more power.
This is a graphic from one of Forchetto's great posts
What I'm getting from the graphs is that at high rpm the power and torque remains the same regardless air port size.
Performance does not increase in proportion to Air flow provided from bigger air port.
Hummm... need to go deeper...
georider is offline
post #178 of 212 (permalink) Old 11-03-2012, 08:26 PM
Lasermax's Avatar
So if I have TWO Polaris bellmouths, having dual openings now, I get to double the length of the line on that chart. That's my math and that's what I'm going with.
Lasermax is offline
post #179 of 212 (permalink) Old 11-04-2012, 06:05 AM
triumphrat.net Vendor
Main Motorcycle: 2008 Bonnie Black Special
PieMan's Avatar
The airbox baffle limits airflow in to the engine at high revs. As I said, if you remove the airbox baffle the engine makes more power to the rev limiter.
Here is a dyno graph showing with the airbox baffle and without.
Mike (UK)
PieMan is offline
post #180 of 212 (permalink) Old 11-04-2012, 11:28 AM
Main Motorcycle: 05 Thrux (in development)
GySchmit's Avatar
Other Motorcycle: 2011 Suzuki DRZ-400S
Send a message via AIM to GySchmit
Red face
OK.... having read this entire thread (and associated linked threads) and trying to figure out a starting point for my carbs my brain hurts! Need this info for my mechanic.
Bike is a 2005 Thruxton (Carb)
Historical info. Bought bike with EMGO Reverse Cones & AI Removed. Over the past two years have removed snorkel and fitted K&N Air Filter.
Bike is being rebuilt from a crash so with it off the road in the shop I'm having/doing the following modifications.
Airbox Restrictor Plate being removed.
Header Crossover pipe being removed and welded up.
Headers being cut just after second bend (when it heads back) and Lossa mini reverse cone mufflers being mounted (ala "TT Style")
Could someone that understands all this data please give me a starting point on carb settings.... Please Please.
Schmit
GySgt, USMC(Ret)
“Notoriety is Fleeting - Anonymity is FOREVER!”
GySchmit is offline
Dyno results after mods Crazy8 Club Cafe' 35 04-21-2008 04:15 PM
Want to buy a 790 intake cam Blacklion50 Air Cooled Twins Technical Talk 1 09-27-2007 08:13 AM
Definitive Answer calliperman Speed Triple Forum 3 11-14-2006 11:33 AM
definitive indoor storage customcafe Club Cafe' 8 12-12-2005 06:33 PM
Definitive differences between 00-01 vs 02-04 RS OKAggie Sprint Forum 27 04-23-2004 11:25 AM
