Oil filters that fit - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
Closed Thread
post #1 of 268 (permalink) Old 06-28-2008, 11:54 AM Thread Starter
Main Motorcycle: 02 Bonneville
Other Motorcycle: Pedal Powered!
Thumbs up Oil filters that fit
I run in to the same problem every oil change, i all ways forget which filters from cars will fit our bikes... if any one has the link to one of threads that i cant find using search that would be great.
02trumpet is offline
post #2 of 268 (permalink) Old 06-28-2008, 09:59 PM
Main Motorcycle: '03 T-100 & '08Tiger1050
Just go to www.calsci.com and go to the motorcycle info section. He has all the filters listed and a lot of other stuff.
Larry
RedBird is offline
post #3 of 268 (permalink) Old 06-29-2008, 12:45 AM
Main Motorcycle: '71 Norton Commando
CommandoRdster's Avatar
Other Motorcycle: '07 Scrambler
Extra Motorcycle: '71 BSA Victor B50MX
I've got essentially this same list on the blogs somewhere:
The CARQUEST,NAPA,and Wix numbers are for sure correct,because I looked them up in the catalog.The other numbers I used a crossover reference,so you should check with the manufacturer of the filter to see if they recommend it for the Triumph.
CARQUEST......85358
NAPA....1358
Wix....51358
Carquest, and NAPA filters are made by Wix.
Baldwin...B1400
Fram.....Ph6017a
Hastings.....LF113
A/C......PF2135
Purolator Pure One...PL 14612
The filter also fits some Subarus and Kias,and a few others I can't remember.
Hope this helps.
Cheers!
Bruce
Sent from my Commodore 64 on dial-up.
ANIMAL RESCUE SITE-Please go there and click on the purple button!
CommandoRdster is offline
post #4 of 268 (permalink) Old 06-29-2008, 12:54 AM
Legend
Main Motorcycle: Tiger 955i
Administrator
Haggis's Avatar
Other Motorcycle: Sprint RS
Extra Motorcycle: Honda XL250
I'm going to sticky that list Bruce.
Haggis is offline
post #5 of 268 (permalink) Old 06-29-2008, 11:39 PM
mobil m-110
hi guys. i used the calsci link and tried to use a non-oem filter for the first time - the mobil m-110. i don't doubt that it filters the oil better - and while i thought i did a pretty good job of applying a light coat of fresh oil before screwing in the filter, it leaks. not badly - but it does leak. wonder if anyone else has had that experience.
2005 Triumph Bonneville T-100
pretty much stock to the bone, 'cept for some af turn signals... so far.
metasac is offline
post #6 of 268 (permalink) Old 07-01-2008, 05:35 PM
Main Motorcycle: '01 Bionic Bonnie
ggRAT's Avatar
Oil Filters for Bonneville
...and here's a cross reference list for Triumph's. A little dated but accurate.
(click on the "small" thumbnail to make it larger, and then click on the "medium" image to make it larger.)
GO:904cc/-AB/-AI/UNI/Jets:150,42,-1.5,3mm/Preds/ceramic hdrs/+3° igniter/180 rear/Ohlins/Works/520X+19Tx43T
SHOW:Pazzo levers/gaiters/Oberon pegs/Naps/new lights/SS braided cables/68 flyscreen,seat & cowl ... View Album
ggRAT is offline
post #7 of 268 (permalink) Old 07-03-2008, 11:35 PM
My experience
I used aftermarket filters and both times they had a very slight leak. I used a Wix and a K&N. Triumphs filters have never leaked. Hate to use triumph filterd due to cost.
You've never rode until you've been throwed.
Anchorbend is offline
post #8 of 268 (permalink) Old 07-04-2008, 11:00 AM
Main Motorcycle: '04 Bonnie Black
BlitzPig's Avatar
The Triuimph brand filters sold in North America are manufactured by FILTECH inc. in Findlay Ohio.
FILTECH is the American subsidiary of Toyo Roki Manufacturing Ltd., the major Japanese manufacturer of vehicle filters. This plant was built to supply American Honda's manufacturing facilities in Ohio.
That is why the OE Triumph filters don't leak. They are made to Honda's manufacturing standards. In short, the OE filters are the best.
Now, the question is, what Honda filter crosses to the Triumph filter.
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
BlitzPig is offline
post #9 of 268 (permalink) Old 07-04-2008, 09:02 PM
Main Motorcycle: 2007 Bonnie
truax's Avatar
Honda Element = Triumph Bonneville
An easy method to remember, the Bonnie uses the same filter as the Honda Element (all years).
I use the Purlator (Wix) filter.
Truax
2007 Bonneville: bar end mirrors, Renntec Engine Guard, MCR Luggage Brackets & Seat Rack, Cortech Saddlebags, GenMar Handlebar Risers, National Cycle Windshield, Hutchinson Custom Brackets, Ikon shocks, Hagon progressive fork springs.
truax is offline
post #10 of 268 (permalink) Old 07-05-2008, 06:49 AM
I find that interesting.I sell dozens(sometimes hundreds) of Wix filters everyday,and I have never had a complaint of leakage from a properly installed Wix filter.
That's good info.
Just as a point of clarification,Purolator and Wix are competing manufacturers.
Cheers!
Bruce
Closed Thread
DNA pod filters Andytwodogs Air Cooled Twins Technical Talk 36 02-15-2011 04:57 PM
Uni Pod Filters Thruxton05 Air Cooled Twins Technical Talk 8 07-17-2010 05:42 AM
K&N Pod Filters RonD Air Cooled Twins Technical Talk 10 01-16-2009 03:00 AM
Did you Oil the K&N filters? Ringadingdoo Air Cooled Twins Technical Talk 2 07-17-2008 10:15 AM
Pod Filters? amanger Air Cooled Twins Technical Talk 1 09-03-2006 03:35 PM
