Headlight and gauges - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
  • 1 Post By 2_Carbs
post #1 of 7 (permalink) Old 06-17-2017, 05:27 PM Thread Starter
Main Motorcycle: 03 bonnie t100
I crashed my 03 a while back damaging the headlight and its brackets .. bike was saved from more extensive damage by landing on me ! .. and after much searching here and and elsewhere on the interweb I think I've come up with fix. I'm on a budget and will need to reuse my original gauges, I like them anyway and all they really need are some new gaskets so I thought the DCC 7" headlight assembly coupled with the LSL brackets would be good. The LSL kit is expensive but I need to be able to attach my bullet signals to them. I was also thinking I'd need a ignition relocation bracket from D9 which I believe would lower the gauges some, tidying everything up and put the key up where I'd prefer. So, has anyone done anything similar to an older ( relatively speaking ) Bonnie ? Would appreciate any advice ... thanks
IrishDave is offline
post #2 of 7 (permalink) Old 06-18-2017, 03:34 AM
Main Motorcycle: 2016 Bonneville T100
2_Carbs's Avatar
Other Motorcycle: 2006 Triumph America LT
Glad your OK, the ignition relocation is pretty straight forward.
Mo' better budget stuff:
Headlight Brackets
http://www.dimecitycycles.com/vintag...ket-dc112.html
http://www.dimecitycycles.com/vintag...-66-35800.html
http://www.dimecitycycles.com/vintag...-66-35830.html
http://www.dimecitycycles.com/vintag...-66-35850.html
Headlights
http://www.dimecitycycles.com/vintag...-66-64312.html
http://www.dimecitycycles.com/6-1-4-...-assembly.html
http://www.dimecitycycles.com/vintag...-66-65010.html
Ignition relocation
http://www.dimecitycycles.com/black-...hand-side.html
Rectifier relocation bracket
http://www.dimecitycycles.com/black-...n-bracket.html
More cool stuff here:
http://carpyscaferacers.com/product-...umph-thruxton/
Forchetto likes this.
"The cycle looms silently over me, ready to start, as if it has waited all night like some silent guardian. From the ground up it looks very impressive. No frills. Everything with a purpose." - Robert M. Pirsig
2_Carbs is offline
post #3 of 7 (permalink) Old 06-18-2017, 12:19 PM Thread Starter
Brillant ! There's a rabbits hole full off great stuff there .. Thanks .. I'd be lost without the incredible help from the likes of yourself and the other members of this site ..
post #4 of 7 (permalink) Old 06-18-2017, 04:29 PM
Main Motorcycle: Newchurch
Pokeyjoe's Avatar
None of those Dime City headlight buckets will work. There's no room in the back for all the wiring - even if you pull the R/R connector and the ignition switch wiring out. I've tried. There are a few buckets out there with the room (and a big access hole), but it will take some looking.
John
3-7-77
Pokeyjoe is offline
post #5 of 7 (permalink) Old 06-19-2017, 10:34 AM
Main Motorcycle: 2001 Bonneville
chicagobob's Avatar
Those headlights will, in fact, work. Any 7" side-mount light will work. A more traditional one would be the Emgo Lucas-style light, which I have on my Bonnie.
http://www.ebay.com/itm/Emgo-Lucas-S...FWFEv1&vxp=mtr
BTW, I still have my stock headlight mounts, and a couple of spare aluminum fork cover tubes. $39 shipped for the stockers, $19 for the tubes.
These are in good condition.
These are just aluminum tubes cut to fit the stock forks, with the stock rubber spacers. The light brackets are just sheet aluminum pop-riveted in place and can easily be removed. This option is 1.25 lbs lighter than the stock headlight ears.
chicagobob is offline
post #6 of 7 (permalink) Old 06-19-2017, 02:58 PM Thread Starter
Looks good .. did you change the gauges setup ?
post #7 of 7 (permalink) Old 06-19-2017, 04:59 PM
chicagobob's Avatar
I'm using a 2.5" mini-speedometer that has all the indicator lights included. Works on the carb bikes.
2015 ACE gauges flicker while running, now won't start Modandrocker Air Cooled Twins Technical Talk 2 05-09-2017 06:53 PM
Headlight bracket mount grommets? Rollinslow84 Hinckley Classic Triples 3 07-19-2016 08:09 PM
Alternative headlight ears Zee9 Hinckley Classic Triples 7 11-05-2015 03:01 AM
2013 speed triple new clipons and headlight nbkyzmo Speed Triple Forum 6 08-20-2015 01:20 PM
Took apart gauges, broke some stuff curbninja Club Cafe' 10 05-11-2015 02:24 AM
