Dynamic chain tensioner - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 14 (permalink) Old 05-14-2017, 07:11 PM Thread Starter
Main Motorcycle: Triumph Scrambler
JamesN1564's Avatar
Other Motorcycle: 64' BSA Royal Star
Has anyone tried one of these? A guy at the Harley hang out said to look into one while he was drooling on my scramble the other day...
https://www.freespiritsparts.com/en/...h-classic.html
JamesN1564 is online now
post #2 of 14 (permalink) Old 05-14-2017, 07:21 PM
Main Motorcycle: 2005 Speed Triple 1050
Mike.Gayner's Avatar
I don't understand the purpose of this device...and the website does a pretty vague job of explaining it. I wouldn't trust anything that comes from the owner of a Harley, least of all matters of chains.
Mike.Gayner is offline
post #3 of 14 (permalink) Old 05-14-2017, 08:58 PM
Main Motorcycle: '07 Bonneville Black
Bjorn Toulouse's Avatar
Other Motorcycle: '78 Kawasaki KZ750B
Extra Motorcycle: '06 Speed Triple
The Buell machines required belt tensioners due to chassis geometry.
The linked outfit is selling billet foo-foo.
Rex
Bjorn Toulouse is online now
post #4 of 14 (permalink) Old 05-14-2017, 10:13 PM
Main Motorcycle: 2007 Blk&Red Triumph T100
Other Motorcycle: '86 Red 883 Evo Sportster
Extra Motorcycle: '81 Red GS450E Suzuki
There is nothing difficult about making the tensioner and if it was useful, it would have been installed on bikes back when they were converted from belt to chain drive. The tensioner needs to be weakly spring loaded to permit variation in rear wheel axle to transmission output shaft center to center distance while the swing arm moves through its travel. The tensioner will simply adjust as needed and so it might as well not be there.
There is a point in swing arm travel when the chain can be no shorter. Chain slack is determined by a mfr. with a known shock length keeping in mind that the chain must have slack during the entire swing arm travel. If you would determine the shock length at minimal shaft c-c distance and set chain slack there, you could use a fixed-mount chain tensioner but there would be slack in the chain before and after that point. Rotate the rear wheel to get minimal slack to account for varied chain stretch.
You can see more if you disconnect the rear shocks and then watch chain slack while moving the rear wheel up and down. Changing rear shock length will require a new chain slack specification.
It would be good to hear from someone who has actually used a chain tensioner and why they like it or not.
Added Note: The above info was posted in reply to a Triumph owner with Triumph and similar bikes in mind.
Ntnbutrbl is offline
post #5 of 14 (permalink) Old 05-15-2017, 07:07 AM
Main Motorcycle: Bonneville T100 Black2012
Captain Bert's Avatar
Other Motorcycle: prev: BSA,Suzuki,Yamaha
Extra Motorcycle: I Wish
Chain Tensioner - back in my younger days I had 1 fitted to my motorcross bike.
With MX bikes there's a lot of rear suspension travel happening. The tensioner reduced constant chain tensioning adjustments and IMO reduced sprocket wear. Reduces chain backlash etc. Weighup if the cost is effective enough to install one.
Would I fit one to my Bonney - tempted but my bike use doesn't warrant it. As the new Bonneys don't leak oil or require maintenance like the old generation, there's more leisure time to tweak chain tension, polish & shine etc
sure
2012 T100 Black : Predators, Ricor Intiminators, Ikon rear shocks, AI restricted, Air Baffle removed, Pretech 6 piston caliper, TTP Tune3
Captain Bert is offline
post #6 of 14 (permalink) Old 05-15-2017, 07:27 AM
Main Motorcycle: 1977 Triumph Bonneville
Other Motorcycle: 1996 Ducati 900ss/cr
Extra Motorcycle: 2007 Ducati S4RS
Tough crowd.
duc96cr is online now
post #7 of 14 (permalink) Old 05-15-2017, 08:22 AM
Main Motorcycle: thruxton
Other Motorcycle: speed triple
Extra Motorcycle: vertemati 501 sm
Useful on a bike with massive suspension movement not much so on a bonnie .
Hedgepig is online now
post #8 of 14 (permalink) Old 05-16-2017, 04:32 AM
Other Motorcycle: none
Extra Motorcycle: none
sure
+1, same here ,off road yes ,road bike ,not needed.
Plasma1.
plasma1 is offline
post #9 of 14 (permalink) Old 05-16-2017, 07:29 AM
Forchetto's Avatar
Some small bikes with Custom styling and long wheelbase need a tensioner as the distance gearbox sprocket-rear wheel is very long, the Daelim Daystar 125 for example, a factory standard fitting:
Forchetto is offline
post #10 of 14 (permalink) Old 05-16-2017, 10:10 AM
Main Motorcycle: 2002 Bonneville T100
Other Motorcycle: Tri, Ducati, HD, Gilera
Extra Motorcycle: "The Knucklution"
ZING!
IMHO, the modern Bonneville platform does not warrant a dynamic chain tensioner. Not enough wheel movement and/or chain length in stock trim.
Now, maybe some of these wild Scrambler/off-roading Bonnies with shocks longer than 370mm justify the mod. I can't see the need on a street bike.
/M
Hedgepig likes this.
Formally known as Retro-Racer on this forum.
RaceDweeb is offline
Chain tensioner over torque flynndigg Air Cooled Twins Technical Talk 5 06-07-2016 12:45 AM
Cam chain tensioner thousandwords Street Triple Forum 16 05-30-2016 08:29 PM
Cam Chain Tensioner Centre Nut Sealing Washer Hotboppincat Sprint Forum 4 12-31-2015 02:34 PM
Cam Chain Tensioner Spring magbhw Hinckley Classic Triples 12 12-28-2015 06:56 PM
Changing cam chain and tensioner CharlieS Sprint Forum 13 06-14-2015 03:32 PM
