Bonneville front sprocket question - Triumph Forum: Triumph Rat Motorcycle Forums
 3Likes
post #1 of 13 (permalink) Old 04-21-2017, 12:17 PM Thread Starter
Main Motorcycle: '09 Bonneville
Question Bonneville front sprocket question
The OEM sprockets/chain kit has a front sprocket with some form of rummer damper integral with it. Aftermarket sprockets do not have this (as far as I can tell). What would the effects be of not having the rubber bits? Does anyone have experience with the aftermarket sprockets?
Many thanks,
Walt
boatanchors is offline
post #2 of 13 (permalink) Old 04-21-2017, 12:36 PM
Main Motorcycle: 2010 Bonneville T100
Brando Cide's Avatar
Other Motorcycle: 1974 CB360
The rubber on the stock sprocket is supposed to dampen noise. I recently switched to an aftermarket sprocket (British Customs) that does not have this and it's fine. Others have said they notice them being a bit louder, but I can't tell the difference.
Brando Cide is offline
post #3 of 13 (permalink) Old 04-21-2017, 12:37 PM
Main Motorcycle: 2001 Bonnie
Other Motorcycle: 2002 Bonnie
Extra Motorcycle: 1250 K8 Suzuki Bandit
It is supposed to damp down chain noise, it doesn't really work after the first few miles. Just use the aftermarket ones, no real difference.
Phil
fullplat1 is offline
post #4 of 13 (permalink) Old 04-21-2017, 01:47 PM
Main Motorcycle: '16 Bonneville T100 Black
justinlself's Avatar
Other Motorcycle: KLR650
Had this same experience on my KLR650. No operational difference between the two otherwise.
2016 Triumph Bonneville T100 Black (2/18/17)
1997 KLR650 (5/28/14 - present)
2016 WI to AK trip NOMEAD
FB Motoblog: Eskimotorrad
justinlself is offline
post #5 of 13 (permalink) Old 04-21-2017, 02:00 PM
The sprocket cover used to include a foam pad fitted to the inside surface, just as usless and eventually deleted.
post #6 of 13 (permalink) Old 04-21-2017, 02:45 PM
Driftless Moderator
Main Motorcycle: 2008 Bonneville Black
BonnieBlack's Avatar
Other Motorcycle: Spousal 2009 Bonnie Black
I don't notice extra noise from the lack of that rubber stuff either.
BonnieBlack is offline
post #7 of 13 (permalink) Old 04-21-2017, 03:16 PM Thread Starter
Thanks to all for the responses. For the significant difference in cost, I'll go with the aftermarket kit, too. At my age, I'll probably never wear the new one out.
post #8 of 13 (permalink) Old 04-21-2017, 08:53 PM
Main Motorcycle: 2015 Triumph Thruxton
yrunvs's Avatar
Location: Prior Lake, Minnesota--just south of Minneapolis
Other Motorcycle: none
Extra Motorcycle: none
Many thanks,
Walt
1 HP.
BonnieBlack likes this.
TTP Tune#3, NH Toga's, Bitubo shocks, D9 bracket, sonic fork springs-90kg, 19 toother, smoked blinker lenses, FP stealth levers, Dime City steering damper, Motone brake relo bracket, gaiters, front fender stay, shock bolt dress up, OEM grab rail.
yrunvs is offline
post #9 of 13 (permalink) Old 04-22-2017, 04:46 AM
Forchetto's Avatar
There's also a sound absorber inside the clutch cover. Together with the sprocket thing it's a way of reducing sound levels for Government homologation tests which involve running the machine past a fixed microphone at a certain speed/revs.
The human ear might not notice the difference, but the microphones will, as they're able to pick up frequencies and noises that we can't. Sometimes manufacturers deliberately over-gear the bike so that it does the right speed past the testing mikes but at lower revs, it's cheating, yes, and the reason why dropping a tooth or two often results in improved overall performance.
Forchetto is offline
post #10 of 13 (permalink) Old 04-22-2017, 11:37 AM
Driftless Moderator
Originally Posted by yrunvs View Post
1 HP.
I ordered a JT front sprocket, simple solid steel. What was delivered was a fancy SprocketLite sprocket all drilled out for weight savings. At first I wasn't impressed, but once I got on the bike damned if I didn't get an extra 1.1 HP. Count me thrilled
yrunvs and Jonnys Bonnie like this.
19 Tooth Front Sprocket mrmach Air Cooled Twins Technical Talk 5 03-29-2017 09:55 PM
Bonneville front wheel help / questions pushrod Air Cooled Twins Talk 10 03-02-2017 12:13 PM
Bonneville Reborn Tour Adamantium Air Cooled Twins Talk 94 12-10-2015 11:01 AM
