Bonneville Handlebar Thread - Page 70 - Triumph Forum: Triumph Rat Motorcycle Forums
 14Likes
post #691 of 1206 (permalink) Old 11-27-2012, 08:01 PM
Main Motorcycle: 2013 triumph bonneville
i bought some emgo "classic" bars, as by spec, they seem like they"ll work fine, i havent had the chance to put them on, but i hope to this week.
villageidiot327 is offline
post #692 of 1206 (permalink) Old 11-28-2012, 10:32 AM
Main Motorcycle: 2008 Bonnie Black
ruger's Avatar
Other Motorcycle: 2007 HD Total Loss
Sounds good. Hope they do the trick for you.
Ruger
Long may you run-Neil Young
ARK/Dominators/Works/Progressive/EBC rotor/Rocket III master cyl/Pazzos/170 rear/D9 Dash/520 chain/Denalis/DEcosse MOSFET upgrade/More crud/Ruger's Garage
ruger is offline
post #693 of 1206 (permalink) Old 12-02-2012, 05:42 PM
well, my bar saga goes like this.......
emgo classics, too high, a bit too much pullback, cut em too narrow. 25 bucks NABD
renthal 794 (yamaha yfz 450) too low, didnt even install them, just rested em in the trees, realized they were too far away/low, 80 bucks, returned em
fly racing steel atv bars, picked em up when i returned the renthal bars. for 18.99 i figured what the hell, maybe they'll be good....... theyre PERFECT. bam
3 pairs of bars, one day. done
post #694 of 1206 (permalink) Old 12-09-2012, 05:56 PM
Main Motorcycle: Harley/Triumph/Suzuki
Other Motorcycle: GSX1400. Bonnie 994.
http://www.triumphrat.net/attachment...93607355093607
I've tried loads of different bars on my latest Bonnie build & have decided to go with the 1" Harley Sportster 48 bars. The feel perfect & have the look I'm after. I've installed all the switch wires internally too to tidy things up. Humdinger.
ID:	57830   Click image for larger version
Humdinger is offline
post #695 of 1206 (permalink) Old 12-11-2012, 12:17 AM
what else ya got going on with that thing? i see forks, tank, some polished bits..... wheres the rest?
post #696 of 1206 (permalink) Old 12-12-2012, 05:57 AM
Just about everything as I just started with a mint 06 carb motor which is going to receive loads of tuning work. This is my 90th bike build since 1969 & my 14th Bonnie, first Hinkley Bonnie though. I wanted to build my ideal Bonnie. I started with making a stronger main frame from 2" 10swg CDS tubing & de raking it 2 degrees. I've used the rear part of a Bonnie frame & lower rails. I've extended the swingarm by 2" & also widened it . Front & rear shocks are Ohlins, I've also made my own Hurricane style tank unit which is 4" wider at the front & 2" wider at the back to take more gas & also it looks so much nicer. I've made an alloy gas tank that fits inside this molding & am about to carbon sheath it for looks. I'm using all new floating discs throughout with twin 4 pots on the front. These will be very useful as I am planning on a hopping the motor up with ether 998 or 1100 cylinders, high comp pistons with porting, larger valves, cams & carbs to hopefully raise the output to the 80 + hp & 70 + ft lbs. At my age I probably wont be making many more bikes so I need to have a few of my favorites to keep & blat around on. My other 2 being a nice Twin cam HD I built in 2001 that I've covered thousands of miles on touring around the UK. Its got 6" over wide glides, my own softail frame, a well tuned 103 cu. motor that goes like stink & is superbly cumfy to ride & handles well. My other being a stock'ish GSX1400 for rain & snow or just scaring the crap out of my self on a sunny day.
http://www.triumphrat.net/attachment...1&d=1355309493
post #697 of 1206 (permalink) Old 12-12-2012, 09:07 PM
get rad!
that looks awesome
post #698 of 1206 (permalink) Old 12-14-2012, 11:46 PM
Main Motorcycle: 2007 Bonnie T100
bonza's Avatar
Other Motorcycle: Jeep Wrangler
Bar End Weights
Originally Posted by ivar View Post
Fitted the Mototwin (LSL) sport touring bars last week, They are narrower than the stock bars and from the pics, looks similar to the superbars from other vendors in shape. As they are both lower and narrower, I found the brake line fitting interfered somewhat with the top of the forks.
Forgot to order bar end weights,so the last pic is an idea I found in a post here, a piece of rubber hose sandwiched between cap and a washer,and a dab of melting glue on the nut to keep it from rotating.
With longer bolts, one could put on more washers etc to get more weight.
LSL Sport Touring are the type of bar I'm thinking of getting
but I dont understand the bar end weights. what are they for?
2007 Tuxedo T100.
Dom Tourers, TTP breathe, DNA filter,baffle gone, 40/140/1 shim 3 turns, TTP igniter tune, Hagon Nitros, Thruxton Bars, Halcyon bar end mirrors, Pingel fuel valve, Monza gas cap, Burton seat, Avon Roadriders
bonza is offline
post #699 of 1206 (permalink) Old 12-16-2012, 12:18 PM
Main Motorcycle: 2003 Bonneville
Mr Jones's Avatar
Other Motorcycle: 2007 Tuono Factory
36" Fehling Flat Bars is what you need!
Old School... from our old friends across the water...
ID:	58053   Click image for larger version
Mr Jones is offline
post #700 of 1206 (permalink) Old 12-19-2012, 08:06 PM
Main Motorcycle: 2003 Bonnie
DJL415's Avatar
Just got my black NH M Bars today, and slapped em right on with some new Napoleon bar end mirrors -
I love the bars! Kinda glad I didn't go with the Hyde Ace bars that I originally had decided upon - I think those would've been too drastic, and most likely would've hit the tank too -
DJL415 is offline
Bonneville pics Jedhook28 Hinckley Twins Picture Forum 1852 05-04-2017 12:25 PM
Bonneville to Scrambler handlebar swap - not possible? Dale_K Air Cooled Twins Technical Talk 45 12-18-2009 04:21 AM
Bonneville Handlebar specs Benthicmerc Maintenance & Workshop Talk 1 07-05-2007 02:27 PM
Bonneville Stock Handlebar Wall Thickness??? road dog Air Cooled Twins Technical Talk 4 10-15-2006 08:08 PM
