Bonneville Handlebar Thread - Page 69 - Triumph Forum: Triumph Rat Motorcycle Forums
 14Likes
post #681 of 1206 (permalink) Old 11-12-2012, 09:28 AM
Main Motorcycle: "Thai" Triumph T100
Other Motorcycle: Previous: 1970 Bonny
Extra Motorcycle: Learned on Sports Cub
Shiming bar end mirrors
Originally Posted by HacksawsGarage View Post
there are commercial available shims.
I bought some great bar end mirrors from Leatherup but the bar size was not listed. When they arrived they were way too small for the 1" sports bars. I cut some 3/4 copper tube with a 1/8th slot to reduce the dia plus a couple of partial cuts. Mirrors fitted cleanly in that and tightened up - so far that has worked fine.
wyomingpat is offline
post #682 of 1206 (permalink) Old 11-12-2012, 12:36 PM
Newbie
Main Motorcycle: Triumph Bonnie T100
Originally Posted by Jpatt View Post
It's an 07. I used the protaper universal 1 1/8" risers and clamps, but used the stock bonneville bolts to hold them in place. The bars are 1 1/8" pro taper carmichael bend. Since the controls ends are 7/8 and not 1" you'll need 1" to 7/8" sleeves that the harley guys use to run dirt bars on their bikes. Or you could source 7/8 controls from a scrambler or 09 and up standard bonnie... I absolutely love the look and feel of these bars, and am super happy with the setup.
Hi guys... Brand new here and have a 2012 T100... Just bought the exact same bars and risers as Jpatt's bike. Waiting on my collars from Joker Machine so I can retain the use of my 1" controls.... It just dawned on me... What did you do about your grips? This set up will leave me with a 7/8's left grip and a 1-1/8" throttle grip correct? Any insight would be great.
Thanks,
Matt
Ti2TTMatt is offline
post #683 of 1206 (permalink) Old 11-12-2012, 04:31 PM
Main Motorcycle: 07 Bonnie
Jpatt's Avatar
The sleeves will bring the 7/8 protaper ends to 1" both sides
he falafal llamma mama
Jpatt is offline
post #684 of 1206 (permalink) Old 11-13-2012, 12:56 AM
Newbie
Hmmm... The Joker Machine collars are only 1.25"s wide as to accommodate the clamps it seems... Any recommendations on other sleeves that may be the width of the grip?
Thanks,
Matt
post #685 of 1206 (permalink) Old 11-13-2012, 08:36 PM
Main Motorcycle: 2012 Thruxton
mike1161's Avatar
Other Motorcycle: '96 Trident 900
Thruxton bar on T100
I've always really liked the Thruxton bar, but had some doubts after reading some of the threads of people who have tried it on a Bonnie, but decided to go for it anyway. Just mounted it today, and took a ride, really love it! Just had to slightly re-route the clutch cable to give it an easier bend, but otherwise smooth sailing! Note there are 2 ways this bar can be mounted, to either give a slight rise or a slight drop. I think Triumph meant it to be mounted with a slight drop, because there are 2 really small dimples on the bar which correspond to how far the switchgear housings should be slid onto the bar before being tightened. Going this way I didn't have any of the throttle interference that others have experienced, but I tried it "upside down", and did have some issues. It really gives a great steering feel to the bike. Here are some photos below:
ID:	57030   Click image for larger version
ID:	57031   Click image for larger version
2012 Thruxton, '96 Trident 900
mike1161 is offline
post #686 of 1206 (permalink) Old 11-15-2012, 09:50 PM
Main Motorcycle: 2013 triumph bonneville
69 pages of bars, im stuck.
i have the stock bonneville bars on, i hate them, they make my wrist at a funny angle, and cause a slight pain.
i dont want to shell out the 120 bucks on flanders flat track bars (though they are my favorite) is there a cheaper alternative?
i suppose its something i'll just have to by multiple pairs and try em all out.
villageidiot327 is offline
post #687 of 1206 (permalink) Old 11-16-2012, 06:41 PM
Main Motorcycle: 2005 Black Bonneville
upchuck64's Avatar
Other Motorcycle: 83 750 Midnight Maxim
I switched to a black biltwell tracker and I'm happy, I had the same problem with the stock ones.
upchuck64 is offline
post #688 of 1206 (permalink) Old 11-16-2012, 09:28 PM
i should have noted that i have 7/8 bars. the biltwell bars are perfect, exactly what i want, but theyre 1"
post #689 of 1206 (permalink) Old 11-26-2012, 09:11 PM
Main Motorcycle: 2007 Thruxton Bonneville
Nickwiz's Avatar
Other Motorcycle: BSA Starfire 1968
Extra Motorcycle: 1930 Triumph NSD.
For 1" try Harley sportster bars. Probably pick some up second hand I would have thought.
Be who you are and say what you feel because those who mind don't matter and those who matter don't mind......Dr Seuss
Nickwiz is offline
post #690 of 1206 (permalink) Old 11-27-2012, 01:45 AM
Main Motorcycle: 2008 Bonnie Black
ruger's Avatar
Other Motorcycle: 2007 HD Total Loss
Here's what you do.
Go to a motorcycle shop which sells Flanders bars or others. Maybe a local Harley independent shop.
Sit on your bike with feet on pegs and, closing your eyes put out your arms just where you want the bars to be.
Don't forget to lean or sit as you would at speed.
The guy from the shop then measures where your hands are relative to the bar clamps.
He gets the width, height, pullback and finds you your perfect bars.
Hope this helps. It worked for me.
Alternately you can try sitting on other Bonnies with different bars at a bike night or whenever you happen upon another Bonnie rider.
And you can always cut an inch or a half inch off each end of a pair of bars with a hacksaw if they feel too wide.
My Flanders Wide Clubmans are perfect (for me) with 1" off each end.
Ruger
Long may you run-Neil Young
ARK/Dominators/Works/Progressive/EBC rotor/Rocket III master cyl/Pazzos/170 rear/D9 Dash/520 chain/Denalis/DEcosse MOSFET upgrade/More crud/Ruger's Garage
ruger is offline
Bonneville pics Jedhook28 Hinckley Twins Picture Forum 1852 05-04-2017 12:25 PM
Bonneville to Scrambler handlebar swap - not possible? Dale_K Air Cooled Twins Technical Talk 45 12-18-2009 04:21 AM
Bonneville Handlebar specs Benthicmerc Maintenance & Workshop Talk 1 07-05-2007 02:27 PM
Bonneville Stock Handlebar Wall Thickness??? road dog Air Cooled Twins Technical Talk 4 10-15-2006 08:08 PM
