Bonneville Handlebar Thread - Page 68 - Triumph Forum: Triumph Rat Motorcycle Forums
 9Likes
post #671 of 1195 (permalink) Old 09-30-2012, 05:28 PM
Main Motorcycle: 2015 Tiger 800 XRx
tntriumph's Avatar
On my mag wheel Bonnie I replaced the uncomfortable 7/8 inch stock bars with the stock bars from my 955i Speed Triple. Perfect fit, with a slight forward lean due to the speedy bars having less rise.
See you somewhere down a twisty road....
tntriumph is offline
post #672 of 1195 (permalink) Old 10-14-2012, 03:23 PM
Main Motorcycle: Bonneville
Originally Posted by Jpatt View Post
What year bonneville is that? and what risers or clamps did you use to make those bars work on the bike? I have an 04 bonneville and i want to get those bars.
zhydro is offline
post #673 of 1195 (permalink) Old 10-14-2012, 05:42 PM
Main Motorcycle: "Thai" Triumph T100
Other Motorcycle: Previous: 1970 Bonny
Extra Motorcycle: Learned on Sports Cub
I just fitted cafe bars - the bar ends I had to drill out. Using a pro quality allen ratchet adapter they were in so tight there was no option - seems that permanent thread lock had been used.
wyomingpat is offline
post #674 of 1195 (permalink) Old 10-15-2012, 11:18 AM
Main Motorcycle: 07 Bonnie
Jpatt's Avatar
It's an 07. I used the protaper universal 1 1/8" risers and clamps, but used the stock bonneville bolts to hold them in place. The bars are 1 1/8" pro taper carmichael bend. Since the controls ends are 7/8 and not 1" you'll need 1" to 7/8" sleeves that the harley guys use to run dirt bars on their bikes. Or you could source 7/8 controls from a scrambler or 09 and up standard bonnie... I absolutely love the look and feel of these bars, and am super happy with the setup.
he falafal llamma mama
Jpatt is offline
post #675 of 1195 (permalink) Old 10-15-2012, 11:56 AM
Main Motorcycle: 2010 Triumph Bonneville
fullspeed's Avatar
Superbars VS. Renthal
Can anyone tell me the difference between Bella Corsa Superbars & Renthal Aluminum Ultra-Low Superbike Bars apart from one is steel and one is aluminum?
fullspeed is offline
post #676 of 1195 (permalink) Old 10-17-2012, 04:50 PM
Main Motorcycle: 2014 Scrambler
goodcat8's Avatar
Originally Posted by beaman View Post
Anybody have a frisco on a bonnie?
Follow up to the above question from 2008.
Anyone?
2014 Scrambler
2012 Bonneville (Gone)
2007 Bonneville (Gone)
goodcat8 is offline
post #677 of 1195 (permalink) Old 10-19-2012, 01:34 AM
goodcat8's Avatar
Pro Tapers High Bend
2014 Scrambler
goodcat8 is offline
post #678 of 1195 (permalink) Old 11-04-2012, 07:40 PM
Newbie
Main Motorcycle: Triumph trophy 650 -1972
Vetshelby's Avatar
My trophy has ape bars and an extended fork .what is stock for a 72 trophy?
Vetshelby is offline
post #679 of 1195 (permalink) Old 11-06-2012, 09:45 PM
Main Motorcycle: 09 Bonneville T100
Other Motorcycle: 72 Honda CB 500
handlebars Help
Hi
I have been looking to put a small custom twist on my 09 Triumph Bonneville. I have purchased some Halcyon 830 bar ends and I am looking for a set of handlebars that gives you a correct look for bar ends but stays true to Original styling. I like Norman Hyde low UK bars they have a 8" pullback. I also like Western Bars handlebars that have a 5" pullback. I could ramble on about this for hours basically I want original style that sets lower than stock to avoid the bar ends looking out of place. The pullback options are basically important to me due to I like comfortable cruising comport.
Timmy T100 is offline
post #680 of 1195 (permalink) Old 11-11-2012, 03:39 AM
there are commercial available shims.
Originally Posted by knhughes View Post
So after reading this post and others I decided to find some Sportster Bars ($17 from a local shop) and put them on. Likewise I love the style of these and the riding position. However the problem I run into is that they are a thinner guage than the stock 1" bars. The interior diameter is closer to 22mm than the 19mm than the stock ones are. This presents a problem when trying to add bar end mirrors (i.e. crg mirrors) as all the billet adapters have a max of 19mm interior diameter for them to work. Any ideas?
If I cant get that to work I have been thinking of getting 7/8" bars. Does anyone know if you can put 7/8" on the 1" mount thats on the 03 Bonnie? Or do I have to get a new mount?
HacksawsGarage
HacksawsGarage is offline
Bonneville pics Jedhook28 Hinckley Twins Picture Forum 1843 03-15-2017 11:33 AM
Bonneville to Scrambler handlebar swap - not possible? Dale_K Air Cooled Twins Technical Talk 45 12-18-2009 04:21 AM
Bonneville Handlebar specs Benthicmerc Maintenance & Workshop Talk 1 07-05-2007 02:27 PM
Bonneville Stock Handlebar Wall Thickness??? road dog Air Cooled Twins Technical Talk 4 10-15-2006 08:08 PM
