clicking noise coming from chain/rear sprocket? - Triumph Forum: Triumph Rat Motorcycle Forums
 32Likes
post #1 of 90 (permalink) Old 03-27-2017, 10:29 PM Thread Starter
Main Motorcycle: 2014 Triumph Bonneville
TryumfBonervill's Avatar
Hey there,
I adjusted the tension on my chain a few weeks ago, and everything was fine. However, I have since noticed a regular (but not exactly periodic) clicking noise coming from the rear of my bike. I did notice that after I adjusted my chain, the silver adjustor bracket on the sprocket/chain side that holds the adjustment screw is canted inwards towards the rear sprocket. I thought it might be that the bracket is hitting the nuts that are on the rear sprocket, but that doesnt seem to be it. I can't quite figure it out. Does this look wrong? How can I nip up the rear axle nut without canting the chain adjustment bracket towards the sprocket? It's definitely not at 65 ft-lb's like the manual states. Thanks!
TryumfBonervill is offline
post #2 of 90 (permalink) Old 03-28-2017, 12:29 AM
Main Motorcycle: 2007 Bonnie Black
mano's Avatar
Other Motorcycle: 2003 HD Sportster 883
Extra Motorcycle: 1990 Honda CB 450 DX
Three things worth checking:
1.Silly question, but did you remove the rear wheel? If so were the wheel spacers put back on?
2.Another possibility, the screw that goes thru that silver adjustment bracket has a small circlip, if that fell off, you may be tightening the screw directly into the end of the bracket, and thus bending it inwards.
3. The front or rear sprocket is worn, and the chain is jumping on a worn sprocket tooth. I once had an intermittent clicking noise, coming from 'somewhere down there'. Drove me nuts. I changed the chain and front sprocket and it was solved.
TryumfBonervill likes this.
2007 Bonnie Black
mano is offline
post #3 of 90 (permalink) Old 03-28-2017, 01:04 AM
Main Motorcycle: Bonneville black 2007
sonicboom's Avatar
Other Motorcycle: Honda CBR600RR
Extra Motorcycle: Honda CB500F
I've adjusted chains and have had clicking noises come and go over the years. I just check things a once over to make sure nothing is falling apart or about to fall off.
I just got done with one of my bikes making a clicking noise, readjusted the chain and it went away, go figure.
sonicboom is offline
post #4 of 90 (permalink) Old 03-28-2017, 02:02 AM
Forchetto's Avatar
A close-up photo would help, or use this one of mine to point out what you think is wrong:
sonicboom and GrumpyGrampy like this.
Forchetto is offline
post #5 of 90 (permalink) Old 03-28-2017, 05:10 AM
Main Motorcycle: Bonneville T100 SMQ SE
Tornado99's Avatar
How much slack did you leave in the chain? Bonneville T100 supposed to be 20-30mm of slack at the midway point along the lower run...measured at the tightest spot on the chain and with the bike on the sidestand, not the centerstand or on a lift....so that some load is on the rear suspension.
2013 T100 Steve McQueen; +NH Togas; -SAI; -O2; +Breathe; +TTP#3; +Avon RoadRiders; +Iron&Resin Sidebag; +Kisan Auto-Off Indicators & BrakeLight Flasher; +MatchlessClueless LED Brake & Indicators; +LED 3000 Lumens Headlamp; +DeCosse Keyless system
Tornado99 is offline
post #6 of 90 (permalink) Old 03-28-2017, 07:21 AM
Main Motorcycle: 2015 Triumph Thruxton
yrunvs's Avatar
Location: Prior Lake, Minnesota--just south of Minneapolis
Other Motorcycle: none
Extra Motorcycle: none
Chains tend to make noises when it's time to replace them and or over tightened. How many miles on your current chain?
TTP Tune#3, NH Toga's, Bitubo shocks, D9 bracket, sonic fork springs-90kg, 19 toother, smoked blinker lenses, FP stealth levers, Dime City steering damper, Motone brake relo bracket, gaiters, front fender stay, shock bolt dress up, OEM grab rail.
yrunvs is offline
post #7 of 90 (permalink) Old 03-28-2017, 07:26 AM
Forchetto's Avatar
A clicking noise is also produced when the nut that holds the gearbox sprocket is a little loose. This is fairly common, even with its tab security washer in place. Remove sprocket cover and check that.
Piercems3 and TryumfBonervill like this.
post #8 of 90 (permalink) Old 03-28-2017, 11:53 AM
Main Motorcycle: 2014 BMW S1000RR
VonEsch242's Avatar
Other Motorcycle: 2004 Triumph Daytona 600
Make sure to check your bearings too
Sent from my Pixel XL using Tapatalk
VonEsch242 is online now
post #9 of 90 (permalink) Old 03-28-2017, 12:50 PM
sonicboom's Avatar
I remember early on people found primary sprockets loose on these bikes. Have not noticed that post lately, since the bikes went over to Thailand.
I have owned Bonneville's assembled in England and Thailand and have found the Thailand bikes to be better sorted.
post #10 of 90 (permalink) Old 03-28-2017, 07:32 PM
Newbie
Main Motorcycle: 02 Bonneville
Other Motorcycle: Wife's 02 Bonneville T100
Had a similar noise recently. Turned out to be sprocket carrier bearing. Cheap & easy to replace all three bearings.
Billy2 is online now
Clicking noise ChrisonTop Cruisers - America, Speedmaster 6 11-10-2016 05:15 PM
Clicking Noise in Driveline 2011SprintGT Sprint Forum 4 04-11-2016 06:33 AM
Sprocket cover removal noise? Iceman123 Air Cooled Twins Technical Talk 3 02-25-2016 08:35 PM
Clicking Noise Under Braking Side-Swipe Triumph SuperSports 15 11-07-2015 09:30 AM
Noise coming from clutch cover AdventureJunkie Daytona Deliberations 8 08-12-2015 12:52 AM
