Cough/ Miss - Triumph Forum: Triumph Rat Motorcycle Forums
 6Likes
post #1 of 32 (permalink) Old 02-10-2017, 05:29 PM Thread Starter
Main Motorcycle: 2007 Bonneville T-100
ATL T-100's Avatar
Cough/ Miss
Hello all, I am new to the RAT Forum but have lurked for many years. Always been able to find the answers to my questions using the great search feature until now.
I have a 2007 Bonnie T-100 with just under 8K miles. The first owner had the Triumph dealer add BC Preds, BC airbox removal with K&N Pods and AI removal. I assume the carb was also re jeted but have not confirmed this.
Bike always fires up quickly and accelerates strong. Over the last year I have been getting an occasional cough/miss under steady throttle. It only lasts a second or two and can best be described as what you experience when you need to switch the petcock to the reserve setting.
My search results lead me to believe that possibly there is an intermittent partial fuel blockage. Am I correct that there are screens over the 2 pipes in the fuel tank that might need cleaning? Also I thought there was an inline fuel screen/filter. But for the life of me I can't see it unless it is between the carbs. The fuel line that appears OEM just goes off the petcock and dives down and disappears from view between the carbs.
So I am looking to confirm how and where to clean the fuel screens and or filter. Also any other thoughts on my intermittent but annoying cough/miss.
Thanks.
ATL T-100 is offline
post #2 of 32 (permalink) Old 02-10-2017, 05:49 PM
Main Motorcycle: '10 Bonneville SE
Other Motorcycle: '07 Ducati GT1000
Extra Motorcycle: After the divorce
Clean out the bowls? Have a look the parts schematics here.
RIP 2010 Bonneville Base
RUPNOK is offline
post #3 of 32 (permalink) Old 02-10-2017, 11:27 PM
Forchetto's Avatar
There's another filter screen fitted inside the "T" piece where the fuel line connects to carbs, see photo. Also make sure the vent hose shown, that terminates under the engine, is not blocked by dirt or water or in a place prone to lots of turbulence that can upset the carburation:
Forchetto is offline
post #4 of 32 (permalink) Old 02-11-2017, 06:37 AM Thread Starter
ATL T-100's Avatar
Forchetto,
Many thanks for your reply.A couple of additional questions for you.
First am I correct that there are fixed screens on top of the filler tubes on the petcock ? If so is it better to take off the tank to remove the petcock or just as easy while still secured to the frame ? Also can I access this filter strainer screen without removing the carbs ?
post #5 of 32 (permalink) Old 02-11-2017, 07:08 AM
Forchetto's Avatar
Originally Posted by ATL T-100 View Post
Forchetto,
I don't have a carbed bike, I only learned these things bumming around on this forum. I'll let a carb man reply...
post #6 of 32 (permalink) Old 02-11-2017, 07:48 AM
Main Motorcycle: 04 T100 blue/white (his)
Wooly's Avatar
Other Motorcycle: 07 T100 red/black (hers)
Extra Motorcycle: 1971 Yamaha DT2 250
Wink
Forchetto,
The tank must be drained of all fuel before removing the petcock I'm afraid.
The screens on the main and reserve ports are easily removed for cleaning once the thing is out of the tank.
I usually just drain the tank via the petcock, remove the tank, then place it on its side while I remove the tap so that any remaining fuel is well clear of the tap and then remove it.
Haven't had occasion to remove the lower filter, but I believe it can be removed without removing the carbs if you are sufficiently dexterous.
Phil.
Wooly is offline
post #7 of 32 (permalink) Old 02-11-2017, 08:50 AM
Main Motorcycle: '02 Triumph Bonneville
Wooly is correct on this effort, I just did it so my memory hasn't failed yet. Many people, including me, remove that small inline filter proactively. Using clean modern fuels it isn't necessary, and adds an additional 'check' on the list of poor running.
Despite my '02 being stored, ignored, and filthy when I bought it, the petcock filters looked very clean. Where I found dirt/grit was at the base, and even between the mounting gaskets. Just nip up the bolts, no need to lean on them.
Good luck -
'02 Bonneville with snorkel, baffle, and AI removed. 138 MJ's, 1 shim, 42's 1.5 turns out, K&N air filter opening enlarged, TPS removed/capped. TORS, Nology Coil, Hotwire plugs, Dart fly screen.
LapinAgile is online now
post #8 of 32 (permalink) Old 02-11-2017, 10:05 AM
Main Motorcycle: 2015 Triumph Thruxton
yrunvs's Avatar
Location: Prior Lake, Minnesota--just south of Minneapolis
Other Motorcycle: none
Extra Motorcycle: none
Good information here for you Alt T-100 but just a reminder to come back and let these kind people (who took the time to help) know how you resolved this problem.
Forchetto likes this.
TTP Tune#3, NH Toga's, Bitubo shocks, D9 bracket, sonic fork springs-90kg, 19 toother, smoked blinker lenses, FP stealth levers, Dime City steering damper, Motone brake relo bracket, gaiters, front fender stay, shock bolt dress up, OEM grab rail.
yrunvs is offline
post #9 of 32 (permalink) Old 02-11-2017, 10:41 AM
Very glad to see the beginning efforts of forum members here to request that those posting problems return the help they've received by either posting their steps toward resolution, or 'I gave up and took it to the dealer'. Simple courtesy.
ATL T-100, also check that your battery connections are clean and tight. When the bike 'bounces' they can loose contact if loose.
post #10 of 32 (permalink) Old 02-11-2017, 10:58 AM Thread Starter
ATL T-100's Avatar
All,
Thank you for your responses. I most definitely will reply back after this. I decided it would be a good idea to replace the 2 small gaskets for the petcock when I reinstall it. Not surprising as I have found with just about everything with the local dealers they will have to be ordered. And like everything from a dealer these thumb nail size gaskets are $3 a piece .
72 T120 miss at high speed when warm. leylandauto Classic, Vintage & Veteran 3 09-23-2016 04:32 PM
No parachute... *** NO PARACHUTE!!! Kirkus51 Biker Hang-Out 6 08-01-2016 11:24 PM
Bonneville T100 EFI cough / hiccup cobalto Air Cooled Twins Technical Talk 22 06-28-2016 01:54 PM
Slight miss coming off closed throttle when warm? triumph beaver Classic, Vintage & Veteran 18 05-27-2016 02:32 AM
Slight miss coming off closed throttle when warm? triumph beaver Vintage Technical Tips & Tricks 2 05-23-2016 03:11 AM
