Right hand shifter conversion? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 8 (permalink) Old 03-20-2008, 06:59 AM Thread Starter
Newbie
Main Motorcycle: Scrambler
tapsak4's Avatar
Greetings from Finland !
I was in an accident in -99, hurt my left foot/leg and it resulted in loss of "tibialis anterior".... the muscle in front of my lower leg.... and at that time a limp left foot. After further surgery a tendon transplant (peronius longus) has enabled me to lift my foot again - but with greatly reduced movement and strength. This results in having to shift up by raising my whole leg.... not very convenient even on the Scrambler not to mention any sports bike.
Has anyone swapped the rear brake and the gearshift levers on these machines? Shouldn't be too difficult.... there's free line of sight along the axis of the brake lever pivot - so that line could be used for a shaft across to the other side.
A new left side peg holder shoud be manufactured to accommondate the brake pedal and the master cylinder.
And yes, my left triceps surae is intact, so braking would be not problem
Thanks,
Tapani
tapsak4 is offline
post #2 of 8 (permalink) Old 03-20-2008, 07:06 AM
Main Motorcycle: Triumph Bonneville T120
Other Motorcycle: Moto Guzzi Breva 1100
Right Hand Shifter
This has been accomplished on Norton Commando's. I have seen several threads on Jerry Doe's Norton Commando Forum. It should be similar and some of the members might have an idea. FWIW.
menzies is online now
post #3 of 8 (permalink) Old 03-20-2008, 01:37 PM
Main Motorcycle: Triumph Speedmaster :)
BorgCymru's Avatar
Other Motorcycle: Another Triumph
Send a message via MSN to BorgCymru
BorgCymru is offline
post #4 of 8 (permalink) Old 03-20-2008, 01:54 PM
Send a message via AIM to WFO750
R/s Shift
Contact Bill Gately at Bonneville Performance. All of his GNC Race Bikes are right hand shift.
http://www.bonnevilleperformance.com/
WFO750 is offline
post #5 of 8 (permalink) Old 03-20-2008, 05:38 PM
Main Motorcycle: two wheeled
grumpy_1944's Avatar
Other Motorcycle: Bonneville black
Extra Motorcycle: thumper
shifting technique
tapani posted;"This results in having to shift up by raising my whole leg.... not very convenient even on the Scrambler not to mention any sports bike."
As a teenager, I rode with a boy who shifted his dirt bike by lifting his leg. I realised why he shifted that way when we went swiming one day. His leg was amputated just below the knee in a car accident about ten years before I met him, and his prosthetic had very limited ankle/foot movement. Sure didn't bother him, I chased that guy all over the hills on my dirt bike.
Practice is cheaper than modification!!!!!
Bill;
I took the road less traveled---------now where in the hell am I??
grumpy_1944 is offline
post #6 of 8 (permalink) Old 03-20-2008, 08:51 PM
Send a message via AIM to CAPTDON
Thumbs up Shifter
I feel for you, & know about amputees. A friend had a Jeep/ stick & I didnt even know till 8-9 mo later? 2 options - Mount the shift lever in a more UP position to make lifting it easier?
Or mount an ecectric shift kit? #2 cost some bucks. The higher shift is free? Good luck & "ride on"!
CAPT D
CAPTDON is offline
post #7 of 8 (permalink) Old 03-20-2008, 10:36 PM
Main Motorcycle: Bonneville
I saw a website with bike modifications for amputees. You might look there, if you can find it. Here is another idea. Make or modify your shifter into a heel and toe shifter. Down shift with your toe and upshift with your heel. That would probably work well and be pretty easy to accomplish, either by adding on to the back of your present shifter or modifying one from a heel and toe bike.
2005 Bonnie, Sleepers and Unifilter, AI gone, restrictor gone, Modre's peg kit, headlight & brake modulator, tach, NC wind deflector, gaiters, steibel, vmax mirrors, Hagons & Progressives, PIAA. http://TexasCoastGeology.com
geolpilot is offline
post #8 of 8 (permalink) Old 03-21-2008, 05:37 AM Thread Starter
Newbie
tapsak4's Avatar
Guys,
Thanks for your responses, ideas and support !
I adjusted the shifter lever two splines down and now I can almost do it ! Haven't tried it with my riding boots on yet, but with rubber boots it almost works.... I need to excercise the small muscle to extend the range of movement and also strength !
Ride on !
Tapani
tapsak4 is offline
hand operated shifter bigdan16 Air Cooled Twins Talk 19 10-28-2006 03:01 PM
Gp shifter or reverse shifter for t595 or 955i a82383 Daytona Deliberations 6 05-09-2006 12:24 PM
Shifter question THX1138 Club Cafe' 5 03-25-2006 06:44 PM
Shifter Question THX1138 Maintenance & Workshop Talk 2 03-17-2006 03:23 PM
Shifter GrayRocketIII The Rocket Science Forum 3 09-27-2005 06:11 PM
