Rear shocks discussed here. - Triumph Forum: Triumph Rat Motorcycle Forums
 6Likes
post #1 of 893 (permalink) Old 11-26-2007, 09:46 AM Thread Starter
Main Motorcycle: T120 '68
Rhodie's Avatar
Other Motorcycle: R1200GS
Best known for their scooter shocks, YSS has quietly been making in-roads on the performance market.
Some years ago the Thai company hired expertise from Europe with many years of experience developing shocks for White Power, Technoflex & Wilburs.
Today YSS is making small runs of high performance shocks for the Big Four special performance bikes.
I have been fortunate that YSS Thailand used their skills on adapting a shock setup for the Scrambler using my bike as a guinea-pig.
Here are the details:
Rear Shocks
Rear fitting of G 366 TRC shocks with correct spring ,
Tailor-made rebound and compression settings.
Installed with correct static sag adjustments.
Length was extended 30 mm from standard shock .
Aussie dealers undergoing YSS training fit my rear shocks
I now have 126 mm stroke , compared to 100 standard of the G366TRC.
YSS will soon be offering this special Scrambler YSS version through their distributors.
Front Forks
Front fork : Use standard spring, modify damping rod and install PD Fork valve 310.
Note they removed my progressive springs I had installed
and reverted to OE with this new fork valve.
The Dogs bark, but the Caravan moves on ... Eastern Proverb
Rhodie is offline
post #2 of 893 (permalink) Old 11-26-2007, 09:47 AM Thread Starter
Rhodie's Avatar
YSS Shocks for Scrambler - Part Deux
Walter Preisig [ex White Power] & Aussie dealers rebuild my front forks
Oil weight was 15 W and air chamber for internal use.
Set Oil height and spring preload to carry specific weight.
In my case - substantial!!
See here for front fork setup
http://www.yss.co.th/pd_fork_detail.php
Materials
All aluminium parts are made of 6000 and 7000 series and are hard anodized.
Shafts are C45 and induction hardened, and hard chromed.
Piston ring and guides are made of calibrated Teflon.
This manufacturing process in line with QS9000 & ISO 9002,
German TUV approved and on even parity with the quality of Ohlins or WP.
Quality Control
Since the inclusion of suspension experts from Technoflex,
Wilburs & White Power YSS have gained ISO & TUV ratings.
Quality control for them is paramount even down to DVD
cameras recording the build of each shock
- so they can bactrack to construction should there be a problem.
For the Bonneville
YSS suggest the Z366TR or go with the G366TR for what they call “more extreme use”.
Which they mean by Offroad , Heavy luggage etc
Thruxton
Similarly for the Thruxton they say for normal street use the E 302 the
Z302 and the G302TRC could do the job.
Depending on your budget and need for adjustability.
Distributors
In the USA please use http://www.yssusa.com
The importer's name is Klaus Huenecke.
In the UK / European distributor thru www.yss-europe.com
In Oz - Link are the distributors and in NZ call Jason @ Thunderbikes.
Finally this setup has given me 26mm additional travel
but more importantly firmed up the riding package
and actually making the bike handle both on and off tarmac.
YSS is not just a cost effective option but it also matches the quality
of its more famous European competitors.
See here for their website www.yss.co.th
Rhodie is offline
post #3 of 893 (permalink) Old 11-26-2007, 03:04 PM
Main Motorcycle: Two wheeled
Retro-Racer's Avatar
Other Motorcycle: several
Extra Motorcycle: next one
Great write-up Rhodie! If I may, let me offer a few insights I've gained running YSS shocks on a Bonneville.
YSS does offer a wide range of shocks, however I've limited my selection to the Z and G series of twin shocks. I've done this based primarily on price. The Economy & Bravo series just didn't do anything for me and I already had other products in their price ranges.
The (Z & G) 302 series of shocks are ideally suited for street ridden Triumph twins which may see some limited off-road/track use. The G366 series is ideal for competition machines or severe-duty street use because of it's more robust construction.
All of the YSS shocks I carry have threaded preload (T) and Rebound Damping adjustment (R). Some have Compression Damping adjustment (C) and/or Length adjustment (L). The shocks I'm using on my flat tracker are the top-of-the-line G366TRCL. The same shocks in a cost-saving street version is the G302TRCL. And as I mentioned in a post a couple of weeks ago, I have 1 or 2 sets of G302TRL at close-out pricing.
I'm having a set of the fork valves installed and tuned as I type. I hope to have a full report soon.
/Mike
BellaCorse
Retro-Racer is offline
post #4 of 893 (permalink) Old 11-26-2007, 07:32 PM
Orpheus's Avatar
Mike, do you foresee any problems with using the longer length YSS shocks on a Bonnie? I read that the G366 shocks are available through BC up to 380mm (I also read on the YSS site that they can be ordered in 395mm and 420mm, though that seems extreme!).
Orpheus is offline
post #5 of 893 (permalink) Old 11-26-2007, 09:00 PM
Is the fork mod a similar product to the race tech gold valve cartridge emulator?
From what I can see, exactly the same.
And what do you mean by closeout prices, Mike?
$459.99 pair.
Mike, do you foresee any problems with using the longer length YSS shocks on a Bonnie? I read that the G366 shocks are available through BellaCorse up to 380mm (I also read on the YSS site that they can be ordered in 395mm and 420mm, though that seems extreme!).
No problems installing longer shocks as long as you don't go too long. I see that Rhodie use +30mm shocks and from the photos you can see how far the bike is tilted over while on the side stand. Because of his off-road use of the bike, I understand the rational for such a selection. But on a street bike (or primarily street ridded) I would say don't go beyond 360mm. The entire YSS line is available to me, however I only list those products that ' I ' believe are best suited for the Hinckley twin range.
/Mike
post #6 of 893 (permalink) Old 11-28-2007, 01:33 AM
Orpheus's Avatar
Rhodie, do the G366 TRL shocks have 100mm of travel or 126mm of travel? I get the impression that you got "special" G366 TRLs with extra travel in addition to length. I'm thinking that the Honda F3 fork mod combined with 370mm long G366 TRLs would be great, since you could retain something close to stock geometry (rake/trail, anyway) while going to 5.1" of travel up front, 4.9" in the rear.
Orpheus is offline
post #7 of 893 (permalink) Old 11-28-2007, 04:03 AM Thread Starter
Rhodie's Avatar
Red face G366 TRL Scrambler Shocks
Orpheus
Sorry if it wasn't clear.
The G366 TRL have been extended especially for the Scrambler.
When I spoke to Walter last week, he told me this will be a special Scrambler version -
though they haven't come up with name designation - beyond my name - which I particularly asked them not to.
Rhodie is offline
post #8 of 893 (permalink) Old 04-24-2008, 06:08 PM
Main Motorcycle: Triumph Scrambler
Jarvis1966's Avatar
Result
Cheers Ben. YSS have sent me an email and I have sent them my requirements. If I get a result I will give them a good hammering around the South East of England, and post my results and photo's. If they work half as good as Rhodies look with them on I will be happy. I used to own a GPZ900 and while all my mates were tinkering with the engine - I fitted decent supension units, tyres, and brakes. result -stock engine(dyno-jetted), 30 BHP down on the others, first home every time! Amazes me how suspension is often last on the list of mod's after engine tuning. If you cant take the speed through the bends - your engine expenditure is under-jetted by your shocks! I hopefully will return with something to report on the handling front. Triumph really should offer a suspension upgrade option with the twins - they really are naughty boys waiting to be unleashed. Even Thruxtons dont show the performance potential possible with these engines. I would of found it impossible to resist the Scrambler Plus model at £700 more if there were factory Ohlins or equivalent on it and decent fork internals......... Come on Triumph, it doesnt have to be wobbly to be retro!!
Jarvis1966 is offline
post #9 of 893 (permalink) Old 04-24-2008, 11:36 PM
Main Motorcycle: Street III
queenpdog's Avatar
Other Motorcycle: mostly BMW's
Extra Motorcycle: TW200
Michael at Bellacorse hooked me up with a set of the Z version YSS shocks for my Scrambler. Okay, I only have about 90 miles on them, but they really transformed the feel of the bike. Fully adjustable, much more compliant, planted, and sure.
This is hard to put into words, but the bike just feels like mine now. Set up for me. Before the new shocks, I felt like the bike and I were a bit at odds on the handling front. Now when I ask her to do something I know she will listen.
Weird, huh?
queenpdog is offline
post #10 of 893 (permalink) Old 04-29-2008, 12:53 AM
I'm not sure what Walter in Oz is doing for the Scrambler, but Klaus here in the US has an excellent handle on shock body length, stroke length, bushing sizes, spring rates, etc. He came up with a Ducati Sport Classic-specific shock by combining different bits & pieces. I'll look into what is being done for the Scrambler next week.
/Mike
Thrux Rear Shocks vs. Bonnie Rear Shocks faffyface Air Cooled Twins Talk 20 02-03-2017 11:50 PM
Hagon rear shocks/150 rear tire ROBD Air Cooled Twins Technical Talk 13 03-29-2013 06:43 PM
New Rear Shocks soon to be available greytop Club Cafe' 12 04-21-2008 12:23 PM
When do you need rear shocks..... pochie Classic, Vintage & Veteran 6 03-29-2008 06:15 AM
Rear Shocks deller4210 Sprint Forum 5 04-18-2006 10:58 AM
