Rear shocks discussed here. - Page 46 - Triumph Forum: Triumph Rat Motorcycle Forums
 6Likes
post #451 of 895 (permalink) Old 11-13-2012, 03:17 PM
al1
Anyone used Betor gas shocks?
Made in Spain I understand.
Thanks.
al1 is offline
post #452 of 895 (permalink) Old 11-19-2012, 12:30 PM
Main Motorcycle: 2005 Bonneville Black
Funkbyte's Avatar
I have been looking for shocks on Ebay and found an auction for some that came off of a crashed Thruxton. They do not look stock but can anyone tell what they are?
Funkbyte is offline
post #453 of 895 (permalink) Old 11-30-2012, 11:22 PM
Main Motorcycle: '11 Speed Triple
Moogs's Avatar
Other Motorcycle: '13 Mag Wheel Bonnie
Originally Posted by Perkology View Post
Just a little update here: I've installed my new Works Performance Street Trackers with ARS (adjustable Rate Spring) on my 04' T100, and I must say, I'm extremely satisfied!! The aesthetics are a huge boost, and more importantly, the performance upgrade is unreal! What a difference!!
(I should include that the rear shocks are Thruxton length - I'm 6'3" and wanted some more height. The steering quickened, but I'm also 225 with full gear, so it's not that noticable, and is something I quite like).
I went with the Street Tracker as well. Did you get the double or single spring? I am 6' 2" 230lb and went with a 360mm also.
Whomever said all good things in moderation certainly never rode a bad ass Bonneville
Moogs is offline
post #454 of 895 (permalink) Old 12-12-2012, 02:55 PM
Main Motorcycle: 2005 Triumph Thruxton
Other Motorcycle: 1970 Honda CT90 Trail90
Extra Motorcycle: 1964 Honda CA105T Trail55
I got a set of the Works Performance Racer shocks from Adrian (adepackett) at his shop in Topanga. He had a set left over from a build project, and he was selling them for a deeply discounted price (about the same as a set of Trackers). Huge improvement! Now I have to work on the front end, and I'm thinking about the Works Performance cartridges.
hapajin is offline
post #455 of 895 (permalink) Old 12-13-2012, 01:43 PM
Main Motorcycle: 2004 Bonneville T100
Went with the double spring. It's' money!
Perkology is offline
post #456 of 895 (permalink) Old 12-16-2012, 11:45 AM
Main Motorcycle: 2003 Bonneville
Mr Jones's Avatar
Other Motorcycle: 2007 Tuono Factory
You just can't beat a good pair of Ohlins!!!
After over a year of trawling Ebay, eventually manged to get a pair of £1500 Ohlins (the fully adjustable type - including hydraulic pre-load), for £550. Almost new. I know not cheap but not that bad for what they are. From the top end Norton special.
Put Hagon progressive springs in the front with heavy weight oil. Still in the build stage and have'nt managed to test ride it yet but can only imagine it will be a huge improvement on the over all handling.
Bike away to Bob Farnham in January for the 903cc bore out and gas flowed head. Just fitted a 170 rear and 130 (17") front on Talon hubs, with 335 front floating disc and 4 pot Brembo. The street rod is starting to take shape. 2 into 1 Zard short pipe, K&N filters, Dyno-jet stage 1 carb kit. Damn this thing is sucking me dry.....
Roll on Spring!!! (it's too feckin cold in Scotland!)
ID:	58049   Click image for larger version
ID:	58050   Click image for larger version
Mr Jones is offline
post #457 of 895 (permalink) Old 12-21-2012, 03:35 PM
Main Motorcycle: 2012 Thruxton
Funkbyte,
I believe those are Ikon Performance shocks; they retail for about $450 new for the black body/springs version:
http://www.newthruxton.com/html/ikon_shocks.html
Paul
haywookp is offline
post #458 of 895 (permalink) Old 01-10-2013, 09:35 PM
Main Motorcycle: 08 Thruxton
Other Motorcycle: 2004 SV650
I just picked up some Hagon classic shocks from BellaCorse and I was wondering if anyone has any tips on installing. Do i need to remove the mufflers? do i need to jack up the bike and if so what is the best way? thanks!!
ChrisHall is offline
post #459 of 895 (permalink) Old 01-10-2013, 09:51 PM
Driftless Moderator
Main Motorcycle: 2008 Bonneville Black
BonnieBlack's Avatar
Other Motorcycle: Spousal 2009 Bonnie Black
I find you need to jack the bike up enough to take some of the weight off the rear wheel. If you try and swap the shocks out one-at-a-time without doing that the bike settles down enough after removing the original that you can't fit the new one on.
Don't know if you need to remove the silencers to get enough clearance to work. Not on my Bonnie, but I don't have those upswept pipes like on your thrux.
BonnieBlack is offline
post #460 of 895 (permalink) Old 01-11-2013, 11:06 AM
would hanging the seat frame from straps attached to the rafters take the weight off? you don't want the whole tire off the ground right?
and thanks for the advice.
Thrux Rear Shocks vs. Bonnie Rear Shocks faffyface Air Cooled Twins Talk 20 02-03-2017 10:50 PM
Hagon rear shocks/150 rear tire ROBD Air Cooled Twins Technical Talk 13 03-29-2013 05:43 PM
New Rear Shocks soon to be available greytop Club Cafe' 12 04-21-2008 11:23 AM
When do you need rear shocks..... pochie Classic, Vintage & Veteran 6 03-29-2008 05:15 AM
Rear Shocks deller4210 Sprint Forum 5 04-18-2006 09:58 AM
