Rear Brake Disk - Hot enough to fry an egg! - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 11 (permalink) Old 08-30-2007, 11:20 AM Thread Starter
Main Motorcycle: '08 Moto Guzzi 1200 Sport
ohiorider's Avatar
Other Motorcycle: 2012 Griso - SOLD
Extra Motorcycle: 1991 BMW R100GS
I had just returned from a short, 15 mile ride, and it was time once again to lube the chain. I brushed up against the rear brake rotor, and noticed it was extremely hot. Checked the front rotor, barely warm. I don't ride the rear brake, and typically use it mostly in very slow traffic, so I don't think operator error is causing the heat problem.
Have any of you experienced overheating brakes? I'm thinking the cause may be sticky caliper pistons that are causing the pads to stay in too close contact with the rotor. Or perhaps the pins that support the pads need cleaned and lubed with some high temp grease. I'll check these things first.
Any other suggestions about what to look for? I'm about ready to change rear pads, and don't want to total them because I've overlooked some simple fix.
Bob
GBNF: 03 T100 Luc Org and Silv: 122/42 jets, TORs, 18T, UNI filter, no AI, Polaris bellmouth, Metz 880 tires, Prog. 440 shocks (105/150 springs), 11-1124 frk springs, Thrux frk caps, gaiters, MotoTwin bars, 6024 lamp, htd grips, 12v outlet.
ohiorider is offline
post #2 of 11 (permalink) Old 08-30-2007, 11:38 AM
Main Motorcycle: 05 Black Speedmaster
Try getting your back wheel off the ground and turn the wheel by hand to feel the drag. There will be some and the disc will get hot but too hot will glaze the pads and can warp the disc. If you are doing the pads anyway, this is the opportunity to correct any problem that may exist unless it's in the master cyl.
Normandy is offline
post #3 of 11 (permalink) Old 08-30-2007, 01:11 PM
Main Motorcycle: 2005 Thruxton 989
Other Motorcycle: 2007 1250S Bandit
Bonnies are known for having the rear pads hanging up on their pins when they get dirty or corroded-easy fix-clean up the pins and lube. Also make sure the reservoir is not overfilled, as this too can cause dragging brakes once the fluid heats up.
thrux351 is offline
post #4 of 11 (permalink) Old 08-30-2007, 02:44 PM
Main Motorcycle: 2005 Aegean Blue Triumph Bonneville
lindsayt's Avatar
Other Motorcycle: 2005 Ice Mint Green Genuine Stella
Extra Motorcycle: 2012 Ivory Stella
My bike's always been that way. I've had it checked out by a couple people, checked it out a couple times myself, nothing's wrong. no runout, no pad dragging, no nothing.
Touch your car's discs right after you stop the car, you'll find they're incredibly hot. My scooter's front disc is ungodly hot. The front disc on the Bonnie isn't hot only because it's in front of the bike's slipstream, which means it gets massive air over it all the time. The rear disc doesn't, so it has to radiate heat through convection.
Remember that modern disc systems never actually lift the pads off the rotors - they're constantly rubbing, just with no force down on them except when you hit the brakes. This is what allows modern discs to have such incredible power, but it also means there's *always* some friction between the pads and the rotor. This generates heat, and of course when you apply your brake, it generates tremendous amounts of heat. Add to that the fact that our bikes have stainless steel rotors, which do not conduct heat very well at all compared to other metals, and you can see that things can get very hot.
I've decided not to worry about it - I've never noticed any fade on the rear brake, and I guess if I were ever cold and stuck next to a broken bike, the rear disc could keep my hands warm for hours!
2005 Aegean Blue Bonneville - Intiminators and Thruxton preload adjusters up front, Ikon 7613s in the back, otherwise stock
2012 Azzurro Fiat 500 Sport
lindsayt is offline
post #5 of 11 (permalink) Old 08-30-2007, 02:58 PM
I find it interesting that the pads do not lift off the rotor, they just sit there. I've noticed that the rear rubs a bit, and my pads are about half gone at 7500 miles even though I use the rear brake lightly and don't ride it.
I've also decided not to worry about it.
Someone mentioned in another thread that a misaligned rear wheel (from chain adjustment) can affect the brake, which makes sense to me. One of the things that I check for chain adjustment is any irregularity in the "rubbing" of the rear disk.
Marty
Baltobonneville is offline
post #6 of 11 (permalink) Old 08-30-2007, 03:34 PM
Send a message via AIM to CAPTDON
rotor
Never touched mine after a ride but i am sure its hot. On the jack there is a slight "sound". The brake got 6000 mi on it & close to replacement. As said your car does the same thing. Unless its warping - not to worry. They never actually do not touch. If there is a real drag on it - then there is a problem.
CAPT D
CAPTDON is offline
post #7 of 11 (permalink) Old 08-31-2007, 09:51 AM
Not really, the caliper and disc move with the wheel so would be uneffected by misalignment.
Normandy is offline
post #8 of 11 (permalink) Old 08-31-2007, 10:54 AM
Main Motorcycle: 2004 Thruxton
The caliper doesn't move.
BLKTHRUX is offline
post #9 of 11 (permalink) Old 08-31-2007, 10:59 AM
i'm glad my caliper does not move with my wheel...that would be bad
G
I just wanted to ride
Geoff is offline
post #10 of 11 (permalink) Old 08-31-2007, 12:47 PM
Move with the wheel "side to side", you guys pulling my chain ?
Normandy is offline
Hot rear rear brake.????? rs_tt Maintenance & Workshop Talk 5 04-11-2007 11:55 PM
955i Rear Brake Disk -- Possible damage Imminent DeanRider Tiger Workshop (archive) 5 04-10-2007 11:53 AM
New brake disk - Again! Lobo Air Cooled Twins Technical Talk 9 09-19-2006 08:59 AM
DISK BRAKE LOCKS UP FLYNHI Classic, Vintage & Veteran 8 09-18-2006 09:59 AM
Brake Disk Bolts Dickie2679 Air Cooled Twins Talk 2 08-26-2006 05:34 PM
