Torque Wrench - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 7 (permalink) Old 08-02-2007, 12:51 PM Thread Starter
Main Motorcycle: 04 Bonnie Black
Other Motorcycle: 76 Bonnie ( CHERRY )
Angry Torque Wrench
Just got a Sears torgue wrench. I do not get how the setting work. Is there a conversion table or what. Sprocket cover setting 9 Nm. I can't find that on the wrench. Has Nm scale but nothing that says 9 Nm. Maybe just stoopid. One you guys have some advice how this works. Thanks
The GWIAZ
Gwiaz is offline
post #2 of 7 (permalink) Old 08-02-2007, 12:58 PM
Main Motorcycle: 2005 Bonneville T100 (B&W) - Chromed like a Harley
raproe's Avatar
Your wrench is probably marked in ft-lb or in-lb. Multiply NM by .738 to get ft-lb or 8.85 to get inch pounds:
9NM x .738 ft-lb/NM = 6.6 ft-lb
9NM x 8.85 in-lb/NM = 80 in-lb
Rich
"....by its very nature, a single-tracker is in unstable equilibrium, i.e., it cannot, when stationary, stand up by itself."
raproe is offline
post #3 of 7 (permalink) Old 08-02-2007, 01:02 PM Thread Starter
Thanks Rich that will work JOE
The GWIAZ
Gwiaz is offline
post #4 of 7 (permalink) Old 08-02-2007, 08:35 PM
Setting the torque wrench
If it's a clicker, turn the handle so the 0 (zero) of the numbers around the handle lines up with the "Newton Meters" scale's vertical line on the metal barrel. Now look at the NM scale on the metal barrel; the top edge of the handle will line up with one of the stamped values on the barrel.
Find the value on the barrel that is closest to but less than the setting you need, and turn the handle until its top edge is at this value, and the 0 on the scale around the handle is at the vertical line.
In this case, turn the handle until the 0 is lined up and the top edge is at "8.69" on the barrel's NM scale. Note that the correct alignment is where the "8.69" line meets the vertical line, not at the number itself.
Now look at the numbers on the handle's NM scale (the smaller scale), and find one that when added to 8.69 will give you the value you need.
In this case use 0.23 (to get final value of 8.92, close enough). Turn the handle clockwise (up) until 0.23 on the handle lines up with the vertical line on the barrel.
You've now dialed in 8.69 on the barrel and added 0.23 on the handle to get 8.92.
Now attach the correct socket and tighten the bolt until the torque wrench clicks/releases once. You're finished. Don't click more times or otherwise fiddle with it.
For storage, turn the handle all the way down to the minimum value.
Or read the directions. It's not a stupid question.
Marty
Baltobonneville is online now
post #5 of 7 (permalink) Old 08-02-2007, 08:55 PM
and yeah as said, tighten bolt till it clicks once. then stop... it is a torque INDICATOR not a torque LIMITER, so you can, easily, overtighten..
merlin is offline
post #6 of 7 (permalink) Old 08-02-2007, 10:27 PM
Main Motorcycle: 2014 Storm
smac's Avatar
Great post balto,
I have a torque wrench that I will now be able to use. The instructions that came with it were written with english words, but didnt sound english when read.
Funny, I don't remember being absent-minded.
smac is offline
post #7 of 7 (permalink) Old 08-03-2007, 11:32 AM Thread Starter
Smile
Thanks Marty, wish you had written the instructions. Very clear Thanks GWIAZ
The GWIAZ
Gwiaz is offline
torque wrench CCR Maintenance & Workshop Talk 11 06-03-2007 08:12 PM
Torque Wrench itcha Air Cooled Twins Talk 9 04-18-2007 12:43 PM
torque wrench bung1 Air Cooled Twins Technical Talk 9 01-02-2007 07:28 AM
torque wrench ? Colonel_Dorkus Air Cooled Twins Talk 10 05-28-2006 02:14 PM
Best Torque Wrench? MaxH Maintenance & Workshop Talk 22 06-07-2005 10:15 AM
