Turbo- Bonnie? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 14 (permalink) Old 11-26-2006, 09:15 AM Thread Starter
Before I do anymore performance mods to my bike I thought I would try to learn about turbo- charging.
Does anyone know if there is a Bonneville specific turbo-charging kit available?
Jojje are you out there?
Thanks, Rick........................
sharpshooter is offline
post #2 of 14 (permalink) Old 11-26-2006, 12:39 PM
Send a message via AIM to Fast_Fashion
i don't know if there is a kit, but people deffinately do it.
IMO it would just be adding more complexity to something that's supposed to be simple and fun.
[ This message was edited by: Fast_Fashion on 2006-11-26 10:42 ]
Fast_Fashion is offline
post #3 of 14 (permalink) Old 11-26-2006, 01:29 PM
Turbo connection makes a kit but I haven't heard anyone use it, in fact I only know of 6 turbo Bonnies and I have built, or helped build, them all.
There are many opinions on how stupid it is to put a turbo on a Bonnie: Buy a GSXR, it looks wrong, it will blow up, and so on. But not one off all the people who have tried my bike say it's a stupid idea, they all think it's one of the greater ideas there have ever been :wink:
A turbo kit is normaly $3,500 and up. I would go EFI too if I was you. I can build a bike for you or just get you the right parts if you like to build one yourself. If you use Megasquirt EFI I can even tune it over the Net!
jojje1963 is offline
post #4 of 14 (permalink) Old 11-26-2006, 01:51 PM
Fast,
There is no simpler way to get 120hk from a Bonnie, and it's still fun. You know that already, don't you :wink:
post #5 of 14 (permalink) Old 11-26-2006, 02:39 PM
Legend
Main Motorcycle: 904cc Bonnie w/magwheels
sweatmachine's Avatar
Send a message via AIM to sweatmachine
jojje, what turbo do you use? Do you use stainless downpipes/exhaust? It looks like it from your pictures...
Do you weld stainless or have it done?
I can weld, but my mig welder is only setup for mild steel. I made exhaust pipes for my XS650 but they're mild steel and I'd worry about rust issues, especially with a turbo where you wouldn't want leaks.
sweatmachine is offline
post #6 of 14 (permalink) Old 11-26-2006, 02:40 PM
Legend
also, have you ever done a high compression/low boost setup?
Seems like a wiseco 904 with 10.5-1 and a mild boost, say 6-10psi would be fun and very rideable.
Course I'm sure your other setups are plenty rideable too.
post #7 of 14 (permalink) Old 11-26-2006, 02:59 PM
On the streetbikes I use a Schwitzer S1BG-L. You should use stainless pipes between the head and turbo since steelpipes can't take the heat. You can MIG weld it with a standard MIG setup but of course it's better to TIG it.
I have tried 9.5:1 but it's no good on regular gas, one reason might be that I don't use an intercooler. 8:1 is perfect though. And don't worry that you won't have enough torque down low, I have 140NM at 2,500rpm but that will only trash the clutch so I never ride it like that. Once you are over 3500RPM there is no lag at all. It doesn't feel like a 120HP 900cc but like a 120HP1,800cc. It's similar to a RIII to ride only much faster
post #8 of 14 (permalink) Old 11-27-2006, 02:37 AM Thread Starter
Thanks jojje, I am getting the bug. Is it true you might be coming to the salt flats this coming september? I f you are I would like to look you up.
Thanks again, Rick........................
post #9 of 14 (permalink) Old 11-27-2006, 03:09 PM
There was talk about a Triumph only meeting at Bonneville, then I would try to go. But I haven't heard anything for a while. It needs planning so I need to know soon or I won't make it.
You could always fly over here and see me racing, and try my bikes!
post #10 of 14 (permalink) Old 11-27-2006, 04:30 PM
Main Motorcycle: 01 Sprint ST Turbo
tommyturbo2's Avatar
Other Motorcycle: 98 TBS
Extra Motorcycle: 1981 Suzuki GS 850G
Sharpshooter: I have a Turbo Connections kit on my 01 ST, and it works great. However, it costs $6K, support from TC is adequate at best, plus if a turbo malfunctions even at a low mileage (my turbo failed at about 3000 miles) it comes out of your pocket, not TC's.
JOJJE's set up uses an turbo with a wastegate (inexpensive), whereas TC's is a variable vane (no wastegate, read VERY expensive $2K). The variable vane turbo is nice because it has no turbo lag at all. A turbo with a wastegate has turbo lag if the turbo is a bit on the large side.
The price JOJJE quoted is an excellent one, especially if that includes the EFI set-up. I hope JOJJE develops an intercooler setup, because that will pull out some of the heat that limits boost pressures. Cheers, tommyturbo2.
TTG..Two Triumph Garage
tommyturbo2 is offline
FI and turbo Bonnie? Doc_Hollywood Air Cooled Twins Talk 1 06-09-2006 05:13 PM
Turbo charged Bonnie Alexius Air Cooled Twins Talk 8 05-25-2006 06:54 PM
R3 Turbo Wadejesu The Rocket Science Forum 8 11-20-2005 09:13 AM
R3 Turbo dacio The Rocket Science Forum 9 11-13-2005 04:45 PM
Bonnie Turbo whooping some sportbike butt Spooner Air Cooled Twins Talk 0 08-09-2005 06:56 PM
