Another led question from the new guy - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 15 (permalink) Old 01-15-2014, 11:25 AM Thread Starter
Main Motorcycle: 2012 thruxton
Nothingfancy01's Avatar
Good day to everyone. I posted this question on the wrong thread yesterday and it was answered quickly by member forchetto. However here is the new revised question. So I have 12 thruxton and have taken off and installed led turns from dime city..obviously they flash to quick.. So I am told all I need is this two prong flasher relay and no load resistors.. But I called dealership today they said I have the proper relay on the bike that it came with. They sAid I need load resistors!! What am I to do. Yes the LEDs flash but fAst at we know.. I am going crazy......
Nothingfancy01 is offline
post #2 of 15 (permalink) Old 01-15-2014, 11:52 AM
Main Motorcycle: Triumph Bonneville T100
deadbroke's Avatar
Pull the side cover and determine which signal flasher you have. Then go to Superbrightleds.com and order yourself an electronic flasher. No load resistors needed.
deadbroke is offline
post #3 of 15 (permalink) Old 01-15-2014, 01:00 PM
Ripper's Avatar
Do not use load resistors.. period. All they do is draw power and waste it as heat, to fool the flasher relay that it has the correct load, ie. bulbs. You need to change the flasher relay to one which is designed to operate low power LED signals. Plug and play replacements, either 2 or 3 prong are available from E-Bay or superbrightleds.com. In your case that should be the 2 prong.
Arrow 2-2, Snorkel/Baffle removed, DNA filter, TTP Tune#3, TEC piggy back gas shocks, 5.5" risers with drag bars, LED Lighting, Hazards, Oberon Footpegs, Burton Seat, D9 bracketry, Hands Free Keyless ignition.
Ripper is offline
post #4 of 15 (permalink) Old 01-15-2014, 01:10 PM
Forchetto's Avatar
There are several sources for a non-load dependant relay which needs no load resistors, there are many sources, some reasonably-priced like this one:
http://www.superbrightleds.com/morei...asher/787/842/
Others not so much, like this one:
http://www.cyclegear.com/CycleGear/A.../p/34262_37823
Forchetto is offline
post #5 of 15 (permalink) Old 01-15-2014, 03:15 PM Thread Starter
Great ordering now, thanks everyone.... need this beast back together!!!!!!!
post #6 of 15 (permalink) Old 01-15-2014, 05:43 PM
Other Motorcycle: 1970 TR6R: SOLD....
Extra Motorcycle: 1999 Yamaha Virago 1100
I found out that the '12 models had a relay (flasher) change during the production run. Early ones, like mine, had the 3 prong and later ones had, obviously, the 2 prong "pigtail" setup. Just check to see which you have.
Jim Ballard
jimballard is online now
post #7 of 15 (permalink) Old 01-16-2014, 08:02 AM
Main Motorcycle: Thruxton
georider's Avatar
Other Motorcycle: Yamaha Roadliner
Extra Motorcycle: Yamaha R1 2015
My 2012 Thruxton had the 2 prong relay.
I bought an electronic relay after replacing the OEM turn signals for LED ones.
At first my relay did not work, the turn signals would remain always on without flashing. Turns out I had installed the relay the wrong way so I just reversed the polarity and now it works fine.
georider is offline
post #8 of 15 (permalink) Old 01-16-2014, 09:12 AM
Forchetto's Avatar
If your bike has a VIN number beyond 521669 then the flasher relay has been changed to a 2-pin type without a ground connection and it's not interchangeable with the earlier 3-pin relay. This applies to all these models: Bonneville, Bonneville T100, Bonneville SE, Scrambler and Thruxton.
post #9 of 15 (permalink) Old 01-16-2014, 11:18 AM
Main Motorcycle: '06 Scrambler/'07 BonnieB
cdubya's Avatar
Other Motorcycle: '05 Yamaha WR 250
Extra Motorcycle: '05 Tiger
Thanks for this Forchetto. So my '07 Bonnie has the 3-pin set up? Is there a plug and play 3-pin replacement flasher to work with LED signals for the three pinners?
Sorry if this has been covered here.... I'm a bit corn-fused....
'06 Scrambler: De-AI'ed, CARK/Uni Pods, Emgo 12" Shorty's, 145mains, 40pilots, stock needles, no shims
'07 Bonnie Blk: De-AI'ed, CARK/Uni Pods, NH Peashooters, 145mains, 40pilots, no shims
'05 Tiger 955i: No airbox plate, Debaffled stock exhaust
cdubya is offline
post #10 of 15 (permalink) Old 01-16-2014, 02:10 PM
Forchetto's Avatar
Yes, same place as the 2-pin, it's model CF13GL-02 here:
http://www.superbrightleds.com/morei...asher/782/836/
LED conversion question Rock2D2 Hinckley Classic Triples 5 10-17-2013 11:40 AM
LED tail light question MercKing Air Cooled Twins Technical Talk 6 04-02-2013 11:49 PM
LED flasher question mep7851 Air Cooled Twins Technical Talk 17 02-06-2013 03:20 PM
5 3/4 LED headlight question shrini23 Air Cooled Twins Talk 2 10-25-2012 12:29 PM
led turn signal question 97daytri Daytona Deliberations 4 02-23-2011 10:45 PM
